swapping gas tanks
Old Oct 21, 2004 | 01:03 AM
fordf150316's Avatar
fordf150316
Question swapping gas tanks
i have a gas tank in a 1988 ford f150 side mount that has a seam leak when filled over halfway full. is there anyway to seal the seams and or would a used tank from a 2003 ford f150 be compatable to swap with the 98. they both look the same. any help would be appreciated
Old Oct 21, 2004 | 02:16 AM
Ford_Six's Avatar
Ford_Six
The 03 tank may physically fit, but the pump assembly is very different. There are some materials that can seal gas, I think it's called Seal-all or something. You should just replace the tank, though, even if it's just a good one from a junkyard. If it's rusted through on the outside, it's probably dumping fine rust and particles into the whole fuel system, which will kill the pumps and plug the filter pretty quick.
