Sponsored by: Auxito
Sticking accelerator
Old Oct 21, 2004 | 12:27 AM
gymbo88's Avatar
gymbo88
Hello,
My accelerator seams to stick whenever I go into passing gear ,or when I push the pedal all the way to the floor. Any suggestions as to what the problem might be, or remedy for repair?
Thanks, Jim (1998 F-150 5.4)
Old Oct 21, 2004 | 11:56 AM
fixer1's Avatar
fixer1
Sticking Accererator
Mine sticks also but it is when you go to accererate from a stop and you end up spinning the tires. If you want to start up easy you first have to accelerate in neutral then put it in gear. any suggestions, or this part of an overall problem? ws
Old Oct 21, 2004 | 05:46 PM
triton_2002's Avatar
triton_2002
I would check the throttle cable where it connects to the gas pedal. Make sure there isn't something stuck back there and then lube it with some WD40. Also check the throttle cable where it connects to the throttle body. There is a braket that holds the throttle cable and cruise control, and make sure the return spring isn't binding up. That's all I can think of, hope that helps.
sgt.bigjim
Nov 20, 2013 09:36 AM
bearhugger
Jun 19, 2013 04:51 PM
raerjim
21
Dec 11, 2006 06:13 AM
Jim242002
20
Mar 2, 2003 07:36 PM
4X4X460X76
Nov 13, 2002 07:16 PM
