Offroad & 4x4
Drive shaft replacement?
Old Oct 20, 2004 | 09:05 PM
AirSmitty's Avatar
AirSmitty
My rear driveshaft is all screwed up on my 75 f250 4x4 with an np203. The guys at the shop want $500 bucks to fix it. Can't I get a brand new custom driveshaft for cheaper than that? Does anyone know of a good shop somewhere in Southern California?
Old Oct 20, 2004 | 09:21 PM
ivanribic's Avatar
ivanribic
I don't know what you've got in your area but around here there are 3 or so good driveline shops that will build a brand new one for about $150. You might also check the junk yards to see if you can get a used one unless you've made some mods that require a special driveline. OR ask the first shop if they offer a free jar of vaseline with that service. Sounds like they're trying to shaft you alright.
Old Oct 20, 2004 | 09:47 PM
fishmanndotcom's Avatar
fishmanndotcom
how about i swap you a 205 for your 203 and then you can get a shaft made easier
if you are bling bling like ivan talk to jesse....his are the sweetest but can be pretty pricey!
a local should be able to lengthen/shorten your current shaft for no more than $150....should be less, but i have been wrong before.
-cutts-
Old Oct 20, 2004 | 09:49 PM
ivanribic's Avatar
ivanribic
I don't even think Jesse charges $500 for a DS like that.
Old Oct 20, 2004 | 10:46 PM
AirSmitty's Avatar
AirSmitty
The driveshaft itself isn't messed up. The whole "double bubble" u-joint thingamajig is a pos and the both yokes are too. My dad talked to the mechanic, so I don't know all the details. It should still be less than $500 right? Would it would be cheaper than 500 just to upgrade to cv joints? Hmmmmmm. We just got the first rain of the year, and I can't even try my truck in the muck. I could probably still pull some chevys out in front wheel drive low.
Fishmann, why would you want an np203 more than a 205???? chain driven vs gear? I'd trade you if i had more time and money.
Thanks alot guys.
Old Oct 20, 2004 | 10:53 PM
ivanribic's Avatar
ivanribic
You mean a double carden? There shouldn't be a whole lot to go wrong with it other than U-joints, unless you actually snapped the joint. Can't you just replace all the U-joints? I think there are 3 with a double carden if I remember right.
I couldn't tell you the cost to go to CV's but they won't cost you $500 worth, I know that.
Old Oct 20, 2004 | 11:14 PM
AirSmitty's Avatar
AirSmitty
Yeah, I read about double cardons online but i wasn't really sure if they were the same thing. Theres some kind of thing between the ujoints in the double cardon assembly. He said theres a gear in it and one of the teeth broke off. Do you have any idea what that could be?
Old Oct 20, 2004 | 11:23 PM
fishmanndotcom
oooo ok....i gotcha, naw man you can rebuild it pretty easy and what you are looking at is usually referred to as a CV-joint....CV being constant velocity!
i suggest you thumb through here and see if what you need is here....don't necessarily have ot buy from here but gives you an idea of what's available to you
http://broncograveyard.com/products/cat/18/106
-cutts-
Old Oct 21, 2004 | 05:32 AM
wyldstallyn73's Avatar
wyldstallyn73
$500!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Id say that shop is crooked and I would never set foot in there again!!!!!!!!!
Old Oct 21, 2004 | 09:47 AM
KJKozak2's Avatar
KJKozak2
For $500 I could have both front and rear shafts made with all new yokes and CTM u-joints. Hell, I could almost get the t-case too for that price.
K.
Old Oct 21, 2004 | 10:43 AM
jopey's Avatar
jopey
there are no teeth on the drive line other than the splines on the slip yoke if your counting them as teeth.
I got my 1310 cv rear driveline with all brand new spicer stuff for $250. I got my 1350 CV's for a little over 3 bills. go there and have them show you exactly whats wrong with the driveline.
Old Oct 21, 2004 | 08:24 PM
RawPower's Avatar
RawPower
Speaking of CV joints, Has anyone seen that new prototype or whatever for the D60s that someone out in Cali is working on? Its supossed to be able to take greater angles and not break as easily. It looks like its from NASA, too.
Old Oct 21, 2004 | 09:13 PM
fishmanndotcom
you talking about the giant birfield looking things?
-cutts-
Old Oct 22, 2004 | 01:47 AM
mustange70's Avatar
mustange70
150 to build a shaft, geeze it cost me more to get a long shaft shortened with a new slip yoke and u-joints and that was just stock replacements when i switched to a 205 case from a 208. Around here it cost 100 a foot to have a brand new driveshaft made and that is a cheap price to.
Old Oct 22, 2004 | 05:58 AM
bremen242's Avatar
bremen242
I buddy charged me $18 to shorten one in his shop... I thought that was expensive
get a service manual- as everyone else said, unless the yoke(s) are destroyed, you can probably get a brand new cv shaft from highangle driveline for unless than that.
