Offroad & 4x4
Drive shaft replacement?
Old Oct 22, 2004 | 10:04 PM
mustange70's Avatar
mustange70
Dang, i'm getting screwed, 50 bucks to have a shaft shortened. Haven't broke one yet, but i haven't dropped in any serious power yet.
Old Oct 23, 2004 | 01:25 AM
thesprocket26's Avatar
thesprocket26
If you need a trail fix for your rigs, my buddies and i conjured up the idea to find an old shaft or bent one and reuse the ends (yokes) but use square thick wall tubing. One end would be like 2.5" inside diameter and the other would fit inside it with a 2.5" outside diameter so they could slide within themselves. Just enough to get you home hopefully, and slowly.
Old Oct 23, 2004 | 07:05 AM
bremen242's Avatar
bremen242
It pays to have your best friend work and a spring and driveshaft shop- he also burned out all of my spring bushings, and replaced a leaf for $30..
btw, there is a thread on pirate about those square driveshafts.. some guys actually use them on the front of their rigs permenately... just don't go fast..
Old Oct 24, 2004 | 12:14 PM
proeliator's Avatar
proeliator
Remember too, that wall size for wall size, square tube isn't as strong as round. Theres one pic with a guy running a square driveshaft that he candycaned over there somewhere. I see using square stock for dl as a temporary fix only, but yea, I guess if you trailered it to and from the rocks it doesn't much matter.
tgtrotter
Jan 19, 2013 10:06 PM
oneill
Flathead V8 & Flathead 6
Jul 19, 2011 02:59 AM
oneill
Jul 11, 2011 08:12 AM
Chazlom
Nov 2, 2005 10:48 AM
luckynjun1
Feb 23, 2001 02:26 PM
