Sponsored by: Auxito
Heater Core Problems???
Old Oct 20, 2004 | 12:54 PM
naturalmeddoc's Avatar
naturalmeddoc
I have a 97' F150 4x4 with a 5.4L. As I was driving to work this morning I turned on the heater and soon noticed a distinct anti-freeze/coolant smell in the cab, presumably coming from the vents. Shortly thereafter, the inside of the windshield began to significantly haze/fog over, which was only alleviated by running the defrost on the cold temperature setting. Are these the classic symptoms of a bad heater core? If so, what are some good tips to use to fix it besides taking out the glovebox, passenger side kick panel, etc.?
Old Oct 20, 2004 | 02:27 PM
banjopicker66's Avatar
banjopicker66
These trucks are notorious for losing heater cores. I jsut had mine replaced. I didn't have the time to fix it, so had to pay to have it done.
$600.
Old Oct 20, 2004 | 05:02 PM
naturalmeddoc
I'm Diggin' In To The Heater Core!
Hi all, just wanted to let you know I'm pretty sure it's the heater core after doing more research. Autozone and O'Reilly's each want $54.99 and their's has a lifetime warranty. Ford's sells for $34.99 and has a 1 year warranty and they will charge me over $500 to do the job. So...I'm Diggin' In! Glove box is out and airbag is next...wish me luck! Oh...I do have a couple of questions:
1. Is it necessary to drop the steering column? I've read elsewhere that it can be done without dropping it.
2. Is it necessary to replace the O-rings on the heater hoses? If so, any ideas on who might carry/stock them.
Thanks!
Old Oct 20, 2004 | 09:28 PM
bosshoss's Avatar
bosshoss
I would get the o-rings and clips from ford. You will also need the foam that goes around the heater core as well. Mark your connectons well and get a box for screws your going to need them. Good luck
Dave P.
Old Nov 12, 2004 | 03:51 PM
naturalmeddoc
Heater Core Fixed, New Problem Though...
Hey everyone, thanks for the tips on replacing the heater core. I installed a new one after many hours of work and it is working great! I also sprayed some diluted bleach into the ductwork to kill any bacteria/mold. Unforturnately, I just realized that I am only getting heat/air through one path...it doesn't change to only the floor, defrost, or dash when I turn the selector ****. Right now it seems to be stuck on coming mostly out of the defrost and some out of the floor...little to none out of the dash. I'm pretty sure it's not the blend door cause' I can still control the temperature.
Thanks again for the help!
