Brake control mounting
Old Oct 20, 2004 | 11:16 AM
deadfish88's Avatar
deadfish88
I have an 04 Ex and a Prodigy trailer brake controller and I'm trying to figure out where to mount it. Does anybody have any suggestions or pictures of their setup? I've thought about attaching it to the fuse panel under the steering wheel, but I'm not sure if I'd be able to operate it very well from there. I've also considered the area under the little cubby hole, but I was planning on using that area for either additional guages or a satellite radio controller. Anyway, I'd just like to see what others have done for some ideas. Thanks!
Old Oct 20, 2004 | 01:16 PM
damone's Avatar
damone
I mounted my prodigy under the cubby. Works out well. I have heard others cut the back of the cubby out and mount it inside the cubby.
For the F250-350 trucks (may apply to Excursions) You can purchase the three gauge (pyro, tranny, boost)setup that replaces the stock cover on the windshelid support arm, sometimes has a Oh crap handle on it. Pretty sweet setup.
I have never really needed to adjust mine while in tow. Usually make small adjustments while stopped. If you need to hit the manual lever you don't even need to see the controller to do that.
Let us know what you did.
Good Luck
Old Oct 22, 2004 | 07:16 PM
Bill4Kath's Avatar
Bill4Kath
I've got mine mounted under the cubby, too. It's not in the way and you can easily reach it while driving. If you want a pic, let me know. The picture will give you an idea if this will be a good place for it or not.
Last edited by Bill4Kath; Oct 22, 2004 at 07:19 PM. Reason: removed the word email
Old Oct 23, 2004 | 12:00 AM
deadfish88's Avatar
deadfish88
If you have a picture, I'd love to see it. I will probably end up doing the same thing with my brake, as it seems to be the best place for it. I think that I've decided on the x-monitor gauge for the A-pillar, so that I can keep the stock handle. A bad back dictates the need for a good way to climb into the cab... :-)
Old Oct 23, 2004 | 08:07 AM
rozett's Avatar
rozett
I also set mine below the cubby. I need to adjust mine very often. When I deliver a load of firewood, the loaded trailer weighs almost 10K pounds. For traveling speeds, I set the controller so that the trailer leads the X in braking. But at low speeds that locks up the trailer bindings leaving black streaks on the customers driveway or bare strips in the their lawn. So when I get to the customers house, I reach down and shut off the trailer brakes. So that location is very convenient.
Old Oct 23, 2004 | 11:54 AM
nanuke1's Avatar
nanuke1
Does anyone use an electric brake controller that is easier to adjust without the lockup?
Old Oct 23, 2004 | 05:49 PM
bluerage's Avatar
bluerage
I mounted a scanner/CB on the hump...with a small bracket from a cb shop...very clean install...then I mounted the brake control on top using a velcro strip. It looks good, is functional and easy to reach if needed with No holes in the dash...
Old Oct 27, 2004 | 05:45 PM
deadfish88's Avatar
deadfish88
Thanks all...I decided to go ahead and mount the brake controller in that location, though I used mirror-hanging adhesive in case I change my mind later on. It works out great there, within easy access/view. Thanks for all the input!
Old Oct 28, 2004 | 02:30 PM
damone's Avatar
damone
You want to make sure that the setting is less than what is required to lock up. Cheap ABS for the trailer when emergency braking.
I'm not sure of an easier adjustment. Not sure of one that the lock up test is even required.
Old Nov 11, 2004 | 02:13 PM
TERMN8R's Avatar
TERMN8R
Here's a few pics, yes, she's dirty. The speaker under the controller is for a hands free phone kit. The gages are trans temp (easy) and oil temp (hard).
Old Nov 11, 2004 | 02:26 PM
deadfish88's Avatar
deadfish88
Good pics Termin8r, looks like the same setup I have - just with different equipment. I posted pics in my gallery...I don't know how to put the pics on the forum yet.
Old Nov 11, 2004 | 09:04 PM
daimon1054's Avatar
daimon1054
Dang Termn8R do you need a trash can?
I see your brake controler and cell phone speaker are in the same spot as mine.
Old Nov 11, 2004 | 09:34 PM
deadfish88's Avatar
deadfish88
You know they have a hook on the dash that would work perfect for holding a trash can!! Haha! :-)
Old Nov 12, 2004 | 11:40 AM
TERMN8R's Avatar
TERMN8R
Well, 116,000 miles since Jan 01, I pretty much live in it. Saw a diesel 02 the other day with 140,000 though.
Old Nov 12, 2004 | 12:56 PM
Bill_T's Avatar
Bill_T
how tuff is the install of the instrument pod? I prefer real guages but have shied away from them based on my assumption they were a PITA...
