fuel pump.
Old Oct 19, 2004 | 11:24 AM
rdeschenes2002's Avatar
rdeschenes2002
Question fuel pump.
Have a 1996 ford f-150, is the fuel pump suppose to make a whining noise when the truck is running,or do you think it starting to go,truck has about 97,000 miles ........
Old Oct 19, 2004 | 11:57 AM
p-car-tower's Avatar
p-car-tower
You should be able to hear the fuel pump when you turn the key on and the engine is off. With the motor running, I doubt you would (should) be able to hear it.
It could be dying, though mine died without making any unusual noises.
The fuel pumps aren't real easy to change since they're in the tank. If you don't drive far from home, you may want to just drive it until it dies before you change it and postpone the work.
Old Oct 19, 2004 | 01:19 PM
rdeschenes2002
Good idea, I was going to drive it till it dies. the only thing is now that winter is coming it most likely will die now while its cold.How hard is it to change any way
Old Oct 19, 2004 | 04:14 PM
1976 F150's Avatar
1976 F150
should make a wee type noise and then stop until the engine is turned over
Old Oct 19, 2004 | 09:54 PM
moose94's Avatar
moose94
Ya mine in the front tank is dead. I just bought one off ebay for about $112. Pretty good deal. I don't know how hard they are to install but I'd imagine it wouldn't be that bad. I'm just going to have a shop do it I think, cause I'm having my headers installed at the same time.
Old Oct 20, 2004 | 07:42 AM
rdeschenes2002
My fuel pump you can still hear it while the truck is running.i too will take mine to the shop and have it fixed....starting to get to cold to work on it outside...
Old Oct 20, 2004 | 08:47 AM
MustangGT221's Avatar
MustangGT221
All fuel pumps whine, some louder than others, you will hear it standing behind the truck, but from the cab you probably can't hear it with the engine running. If you have two fuel tanks, than you can just run on 1 tank if the other pump fails. I've got to replace my fuel pumps soon, for mine I will remove the bed and change the pumps from the top of the tank, rather than drop the tank. It's only a few bolts and a couple of guys to pickup the bed...pretty easy to remove and instant access to the tanks. I will also sandblast my frame and clean it up nice.
Old Oct 20, 2004 | 09:34 AM
gatesj's Avatar
gatesj
I have a brand new pump in one tank of my old truck and an old one in the other. They're both loud enough to hear with the truck running, even the brand new one. I bet trucks with the I300 have pumps that are louder because they run the fuel rail at a higher regulated pressure. This truck I'm talking about has a 300. But I can hear the pumps on my 351 truck too if I walk around to the back of the truck while it's running. Both are post-'90.
I wouldn't worry about it personally.
Old Oct 21, 2004 | 07:34 AM
rdeschenes2002
Yea, if you stand behind the truck you can hear it ,someone told me that it was probably starting to go........
Old Oct 21, 2004 | 11:08 AM
gatesj's Avatar
gatesj
Like I said, I put a brand new Napa one on and heard it right away right after I put it on.
If it's smooth and fairly quiet it's OK. You can hear the difference when they sound sick.
Old Oct 23, 2004 | 05:47 AM
MATT1971's Avatar
MATT1971
I'd replace the pump now instead of risking needing a tow later. Just wait till the tank is near empty (much easier to handle), get a floor jack with a 1'x1' piece of plywood on the pad so as not to damage the tank then undo the straps lower it just enough to undo the lines, etc, then drop it the rest of the way. To install just reverse procedure. By the way when you change the pump be sure to replace the sock filter,it's cheap insurance and will probably extend the life of the replacement pump.
Old Oct 23, 2004 | 06:52 PM
my93's Avatar
my93
Just to add, when removing the tank be careful to remove the electrical plug on top of the tank. It has a snap in plastic clip. BTW, Advance sells the entire pump with the plastic body and the screen for $134. You use your old float/sending unit arm assembly
Old Oct 24, 2004 | 08:54 PM
great300's Avatar
great300
You`ll find out you`re better off replacing both pumps. I just went through it all. Ran on one new one old....started running like crap....fuel press. dropout etc, replaced other one too, now runs great....
Old Oct 24, 2004 | 10:43 PM
88'f150_300's Avatar
88'f150_300
Actually, the 300's have a low pressure fuel pump in the tanks and a high pressure one on the frame right under the driver door. The one in the tank just keeps the high pressure pump from having to work so hard.
Old Oct 25, 2004 | 07:32 AM
rdeschenes2002
Thanks to everyone who replied to my post, i am just going to leave it and see what happens. keep you posted.....
