Auto MAF in 5-Speed
Old Oct 19, 2004 | 08:57 AM
theedge900's Avatar
theedge900
Auto MAF in 5-Speed
Will a MAF setup out of a 94-95 F150 automatic work in a 93 with a 5-speed without any major problems?
Old Oct 19, 2004 | 09:16 AM
EPNCSU2006's Avatar
EPNCSU2006
You will get transmission trouble codes and a constant check engine light likely. I don't know what that will do to driveability though. If it were for a non-electronic transmission, it would probably be fine, but since it controls the E4OD, I don't know what that would do with no transmission to control.
Old Oct 19, 2004 | 09:57 AM
theedge900's Avatar
theedge900
Did they ever put a MAF in the 5-speed 302 prior to '96? If I were to use the MAF system out of the Auto and use a 5-speed computer, would that work? What about using a Mustang computer in a Truck MAF system, of course changing the appropriate pins?
Old Oct 19, 2004 | 11:02 AM
EPNCSU2006's Avatar
EPNCSU2006
I want to say that there was a 302-5 speed MAF combination, but I don't know for sure. You should be able to use the wiring harness at any rate, and just change the computer. It should be easy enough to use the truck MAF wiring as long as you match up pins to the mustang computer. That should work fine, and while you are moving pins, you could just take out the ones for the transmission.
Old Oct 19, 2004 | 01:36 PM
Kemicalburns's Avatar
Kemicalburns
go here www.fordfuelinjection.com and read up . personally i think finding a mustang harness and ecu would be the way to go. or the guy running that site builds custom harnesses.
late
Old Oct 19, 2004 | 10:22 PM
EPNCSU2006's Avatar
EPNCSU2006
If you have access to a truck MAF harness, use it anyday before trying to splice in a mustang harness. The mustang ECU should match up after moving one or two pins, and removing the transmission control wires if it's an automatic harness.
99svtlightning2
Escape & Escape Hybrid
Sep 7, 2014 01:27 PM
hav24wheel
Sep 22, 2010 01:24 PM
J23wlsc
Oct 11, 2007 09:07 PM
fimar7
1983 - 2012 Ranger & B-Series
Jan 12, 2005 06:00 PM
