Aerostar Ford Aerostar
trailer wiring ?
Old Oct 18, 2004 | 10:46 PM
ktmkid's Avatar
ktmkid
trailer wiring ?
My 89' Aerostar XL has amber turn signals, does anyone know a
good way to wire in a 4 wire trailer harness? If I put in a jumper
wire to have brake lights and turn signals, then the amber and
red both work together on the van because they back-feed to
each other.So on the van if you step on the brake, the brake
light and amber turn signal both come on, and if you use the
turn signal the brake light also flashes. Will this cause problems
with my electrical system on the van? Last time I ran a jumper
wire, I ruined a switch before Tom F. could warn me not to.
Old Oct 19, 2004 | 08:30 AM
pbrunner's Avatar
pbrunner
Sounds like the same system on my mazda pickup. I had to wire in a control module that converts the separate brake/turn signal circuits into a single one. It cost a little about $20 at the auto parts store, but that was 15 years ago.
Old Oct 19, 2004 | 09:45 AM
ktmkid's Avatar
ktmkid
Sounds like the ticket, I will check into one of
those modules. I sure don't want to fry any
of the wiring or a computer.
Old Oct 21, 2004 | 10:20 PM
MO51's Avatar
MO51
Trailer wiring
I had a 95 extended, now have a 96 extended. I too went the aftermarket module route for 4 wire trailer. The various catalogs seem to have a made to fit trailer wiring hookup for every Ford product except the Aerostars. Ranger wires don't fit. It's been working for 6 years now, never a problem. 'Wired it in front of the left tail light assembly, easy access.
Old Oct 22, 2004 | 12:28 PM
ktmkid's Avatar
ktmkid
That's what I did, last night I wired in the converter,
and it works fine. Thanks guys!!!
DonsFx4
2004 - 2008 F150
Jul 16, 2019 11:55 PM
sere0501
Jan 3, 2015 12:06 AM
SD26
Apr 7, 2009 09:04 PM
petalynne
Electrical Systems/Wiring
Jun 19, 2007 03:27 PM
krelvinaz
Jun 1, 2004 06:02 PM
