1979 with 400m
Old Oct 18, 2004 | 07:28 PM
haulin4's Avatar
haulin4
1979 with 400m
i have got a 79 4x4 with a 400m in it i dont know forr sure if the motor woks or not i traded the truck for an old camper we had i wanted it for the parts off of it but now am thinking about maken her a show truck or a play toy .
i ahve heard alot of negatives about the 400m .i would realy like to have a 460 in it but if i can get the 400m running and soforth i may just keep it
could you folks give me the good and bad sides of the 400m
i cant seem to post pics here or i would show you how ruff the motor looks
haulin4
Old Oct 18, 2004 | 09:58 PM
Torque1st's Avatar
Torque1st
Posting Legend
First off you have a 400 no "M" the letter designations were only used with the different 351 engines.
The 400 is a torque engine. It would be good for snow plowing. It is capable of getting better fuel mileage than the 460. The 460 has to be geared real high, higher than most of the available HD rear axles to get good mileage just because of all those cubes turning over. The 400 has a long rod and a long stroke that works for torque but it is not a high revving engine. People have built them to run 800HP but that is not something you can run on the street. If the motor runs and does not rattle or smoke too bad it may run for years.
Good luck with it!
Old Oct 19, 2004 | 02:01 PM
tastyklair's Avatar
tastyklair
The cons are the way the engine was detuned from the factory to meet emisions standards. The pros are there is any where from a very little to a whole lot that can be done to wake up this sleeping giant. Check out these for starters. http://home.earthlink.net/~bubbaf250/index.html
http://www.projectbronco.com/Technic...e_build_up.htm
Old Oct 20, 2004 | 05:48 AM
Colo79Ford's Avatar
Colo79Ford
Just for some motivation....$1300 rebuild on my 79 w/ 400 vs $2700 rebuild on a 78 w/ 460. The 400's 4x4, the 460 is 4x2....I can outrun, the 460 whenever i want. A 400 is a good motor to wake up. If you want to stick with it, thats what i would recommend. Can be a great motor.
---JOHN
Old Dec 10, 2004 | 12:00 PM
king543's Avatar
king543
Smile
my stock 400 terns 6,000 RPM with wild tork but they Have main baring problems.go with 400!!!!!
Old Dec 10, 2004 | 01:03 PM
F150daniel's Avatar
F150daniel
"i ahve heard alot of negatives about the 400m"
exactly which negatives have you heard? theres a few that aren't true.
the 460 has few too.
superduty4x4
Oct 6, 2007 10:29 PM
lilman320
Apr 21, 2006 07:30 AM
oldog/newtrick
New Member Introductions
Jan 14, 2006 07:56 PM
haulin4
Nov 9, 2004 04:13 PM
superfsh
Engine Swaps
Sep 22, 2004 09:19 PM
