transmission problems?
Old Oct 18, 2004 | 06:16 PM
matareno's Avatar
matareno
after 2yrs i just got my '55 f-100 rolling. now i can't find the reverse on the column shifter. i was told it was a three speed so the reverse should be above 1st but its switching gears like a four speed but without reverse. if anyone has ran into this problem or just has a clue of what i'm doing wrong. please let me know. all the gears change perfect just without a reverse.
Old Oct 18, 2004 | 06:23 PM
57_ford's Avatar
57_ford
3 speed on the column should go like this pull to you back and up should be reverse then strait down should be first then push and up is 2nd and strait down from that is 3rd.
