IDI? International Direct Injection?
Old Oct 18, 2004 | 05:41 PM
Jacksfirstdiesel's Avatar
Jacksfirstdiesel
Is this what the acronym stands for? Sorry if it's a dumb question. Just trying to learn what I can
Old Oct 18, 2004 | 05:43 PM
04F250CC60's Avatar
04F250CC60
Indirect Injection
The injector is positioned in the intake runner and fuel is injected as the intake valve opens and piston is on it's intake stroke. Since fuel is not directly injected into cylinder on compression stroke as in a DI engine it's called IDI. Much less fuel presure is required. Much less efficient than DI. Very old school. Basically it's fuel injection for diesels.
Old Oct 18, 2004 | 05:48 PM
Jacksfirstdiesel
Would an '87 6.9l be considered indirect injection then? Thanks
Old Oct 18, 2004 | 06:06 PM
bilder12's Avatar
bilder12
Yepper, the older diesels are idi (indirect injection). The fuel is sprayed into a precombustion chamber. Kinda like warms it up before it compresses it. The old old caterpillars were the same way. The change to direct injection came somewhere in the 94 model year with the power stroke designation.
Old Oct 18, 2004 | 08:02 PM
Birken Vogt's Avatar
Birken Vogt
Originally Posted by 04F250CC60
Indirect Injection
Not at all accurate, no diesel injects fuel on the intake stroke. Rather, indirect injection (as said correctly before in this thread) injects it into a pre-cup which is a small chamber connected by a passage about the size of a pencil to the main chamber where the piston lies. The purpose if this small chamber is to get a flame started which then helps to futher atomize the fuel as it is shot out into the main chamber. As stated allows a lower pressure injection pump, and is not used much today.
Birken
sparkkky
2004 - 2008 F150
Aug 21, 2011 03:02 PM
SuperSnake
Maryland Chapter
68
Jul 9, 2008 12:17 PM
JByrd1173
Dec 11, 2004 03:35 AM
3.8 & 4.2L V6
Jan 23, 2003 10:01 AM
bigsnag
Nov 22, 2001 10:35 PM
