ipod
Old Oct 18, 2004 | 03:28 PM
MMZ2584's Avatar
MMZ2584
ipod
was wondering if anyone had any suggestions on where to mount a ipod at. So it is accesible and visible and also able to take out i had some ideas but just wondering if anyone else has done this.
Old Oct 18, 2004 | 08:09 PM
ScruDriver's Avatar
ScruDriver
I'm thinking about getting a mount myself, and so far the best I've seen is from ProClipUSA. The website is the same as the name... Good luck!
Old Oct 19, 2004 | 12:27 AM
noahr's Avatar
noahr
what i did was simple. I just used a small pice of velcro and mounted it beside the heat/air control. check out my gal for pics!
Old Oct 19, 2004 | 08:52 AM
tomsf1ffty's Avatar
tomsf1ffty
Noahr Wiring?
Noahr:
How did you tap the wires into your system? I am using a Belkin FM modulator which has too many wires all over.
Thanks
Old Oct 19, 2004 | 12:06 PM
noahr's Avatar
noahr
I'm using a belkin car kit. It provides 12v power as well as a mini output witch i converted to rca with a small cable. Its much better than any fm mod. check it out
Old Oct 19, 2004 | 01:43 PM
tomsf1ffty's Avatar
tomsf1ffty
Belkin Lighter Adap6ter or Direct wired?
Thanks. I'll check it out. When you say a Belkin Car Kit, I have the plug into the lighter belkin kit. Do you have something different or did you convert it to tap directly into 12V? I'll check out Belkin's site too.
07 F250 Aggie Mobile
6.7L Power Stroke Diesel
Jun 20, 2012 08:32 AM
Will89
Nov 11, 2008 01:05 AM
fordman2267
Apr 11, 2008 07:44 PM
patriots6800
2004 - 2008 F150
Jan 25, 2006 08:07 PM
