93 Ranger Chirping?
Old Nov 14, 2002 | 11:01 PM
rick_mack's Avatar
rick_mack
93 Ranger Chirping?
My 93 Ranger (3.0L, 5 spd) has begun to make a chirping sound when I accelerate. I don't here this sound when idling - only when accelerating. A few days before this I put some water remover and some injector cleaner into my full tank of gas. A buddy mentioned that this clicking or chirping could be a result of the additives and that it should go away when the gas is emptied and replaced. I'm hoping this is the case but what do you guys think?
Old Nov 15, 2002 | 01:28 AM
Torque1st's Avatar
Torque1st
Posting Legend
93 Ranger Chirping?
Your serpentine belt is probably beginning to slip. Search the for suggestions on how to prep your pulleys if the belt has done any slipping, otherwise the new one will start slipping soon also.
Thanks for using FTE!
[font color=red]As a Moderator I do not "Subscribe" to most topics,
please send email/pm if you need a reply -Thanks![/font]
Old Nov 16, 2002 | 11:57 PM
Starratt04's Avatar
Starratt04
93 Ranger Chirping?
its either your belt or your valves
Old Nov 26, 2002 | 07:31 PM
rick_mack's Avatar
rick_mack
93 Ranger Chirping?
I've replaced the belt. Chirping persisted. However, I filled up the gas tank after I used what was in there (the water remover and injector cleaner). The chipring went away - until today. It still seems to spit a lot of water when idling (it's cold here in Alberta now)and it's running rough and seems to lack the power I used to have. The plugs have recently been replaced and the wires and distributor about a year or so ago.
When you say valves - are we talking $$??
Thanks guys.
Old Nov 26, 2002 | 10:01 PM
Torque1st's Avatar
Torque1st
Posting Legend
93 Ranger Chirping?
When you replaced the belt did you clean the pulleys per my instructions? I can't see where moisture in the tank would cause engine chirping unless you were getting a nasty miss. Down here in USA the moisture in the tank comes from the alcohol in the fuel.
Old Dec 12, 2002 | 03:43 PM
Squiggy's Avatar
Squiggy
93 Ranger Chirping?
Alcohol?? Fuel?? Double wammy. LOL:-X12
Old Dec 13, 2002 | 02:12 AM
mathelm's Avatar
mathelm
93 Ranger Chirping?
Could it be your catalitic converter stoping up? And the chirping is exhaust blowby at your donut gasket. Too too much alcohol in your fuel. Never put that water away crap in your fuel, just fill the tank insead.
Old Dec 13, 2002 | 04:51 PM
gt_hank's Avatar
gt_hank
93 Ranger Chirping?
