vibrations
Old Oct 18, 2004 | 02:28 PM
250jl's Avatar
250jl
vibrations
i have a 03 psd with a 2.5' leveling kit on it and a new set of 315/75/16 bfg at's. my truck shakes bad when im driving on the highway at speeds over 50 mph. im not sure if its the fact that i have beefier springs in the front or what. i know its now the tires because they dont have more than 4000 miles on them. my truck did this before i had this new set of tires. the old set of tires were bfg muds in the same size, i thought it might be the fact that the muds were worn out and out of round and that was why it was acting up but its continued since then. any thoughts or suggestions are appreciated. thanks
Old Oct 18, 2004 | 04:09 PM
bodabdan's Avatar
bodabdan
Veteran: Navy
You may need to lower your carrier bearing that's on your driveshaft. Raising a truck will change the angle on the u-joints. I have heard that the carrier bearing should be lowered 1/4 inch for every inch of lift. Place the appropriate shim between the bearing and where the bearing mounts. You may need longer bolts. You should verify this figure for yourself before you follow my advice. I suspect that this will at least help.
If you truck is 4WD it is possible to remove the rear shaft and drive on the front end only. If the vibration goes away then you at least know it's in the rear driveline.
