cig. lighter
Old Oct 18, 2004 | 09:00 AM
beartracks's Avatar
beartracks
cig. lighter
Anyone no offhand what holds the cigarette lighter socket in place? Mine is loose and I can't get my hand up in there due to gauges in the way.
Old Oct 18, 2004 | 09:16 AM
73Custom's Avatar
73Custom
There are threads on the back of the socket and a pressed metal 'nut' that tightens it against the dash.
Marty
Old Oct 18, 2004 | 09:31 AM
teepee542's Avatar
teepee542
I have sometimes been able to tighten mine. I remove the lighter an use my fingers to rotate the socket clockwise while pulling it torwads me. Pulling it pulls the nut up against the dash and stops it from turning.
Old Oct 18, 2004 | 10:21 AM
Mil1ion's Avatar
Mil1ion
It is a 2 piece tubular shape.
The outside sleeve screws onto the inside part of the lighter & with it's shark type teeth on the end,grabs & holds on to the back of the dash,
Hold the lighter in front with your left thumb & with your right hand reach under and twist the other part clock-wise til it's tight.
