Bad U-joints
Old Oct 18, 2004 | 07:42 AM
jcs1966's Avatar
jcs1966
Bad U-joints
AS I drive down the road I get like waves of vibration. Local mechanic said ujoints are o.k., and tires need rotated but girlfeind says hers were FROZEN and would move anymore and she got same probels
Old Oct 18, 2004 | 07:57 AM
sandrat's Avatar
sandrat
A vibration isn't necessarily a u-joint issue, nor is it a wheel balance one. To check the joints, just see how much play there is in them by turning the driveshaft. Having the tires rotated and balanced isn't that expensive, and eliminates that possiblilty.
Old Oct 18, 2004 | 12:37 PM
andym's Avatar
andym
U-joints can cause problems even if they seem tight. If you're in doubt, they're easy to replace. Also, check and see that the pinion nut hasn't backed off. That can cause vibrations.
