How big an Alternator?
Old Oct 17, 2004 | 11:01 PM
elemint's Avatar
elemint
My alternatory is not putting out enough power to keep my truck running so i need to replace it. Now many Amps should i get? I have a campers special and the stock on back in 67 was 55 amps. Is that big enough?
Old Oct 17, 2004 | 11:25 PM
Mike W's Avatar
Mike W
It is big enough unless you have added a lot of electrical stuff.
Old Oct 17, 2004 | 11:28 PM
Faithful Old Road Dog's Avatar
I recently picked up a rebuilt alternator and the only listing for it was 67 amps or so. I asked if there was a higher amp and was told that's all the book shows for a 71. I always like to get the biggest amp option I can get without having one custom built. 55 Amps sounds a bit low to me but that all depends on what you're running, ie. aux. lights, halogen headlights, CB radio, custom stereo, winch...
Old Oct 17, 2004 | 11:47 PM
4x4Subaru's Avatar
4x4Subaru
I run a 65 amp one-wire alt w/dual batts and Hella headlamps w/ 80/100 watt bulbs. It seems to do the trick.
Hey Faithful Old Road Dog. You still using the Hella headlamps?
Old Oct 18, 2004 | 09:20 AM
elemint's Avatar
elemint
One wire? I have 3 on mine. Do the One wire ones come with a wire?
Old Oct 18, 2004 | 01:19 PM
4x4Subaru's Avatar
4x4Subaru
Yes, only one wire. That is why they call it a one-wire. The wire runs directly from the +post on the alt to the hot side of the solinoid. The alt has to be converted over to allow this. Either you can do it or buy a one-wire alt from the auto parts store.
Old Oct 18, 2004 | 09:44 PM
4x4Subaru- Yeah, I'm still using the Hella 80/100. Not a blink since I've installed the relays.
Old Oct 19, 2004 | 11:30 AM
baitmaster's Avatar
baitmaster
I have a 100 amp 1-wire alt sitting on the shelf, because I wasn't sure how to hook it up. So you run wire from alt to hot side of solenoid? What did you do with the wires that were unplugged from the regulator? I have a '72.
Old Oct 19, 2004 | 01:10 PM
Mike W's Avatar
Mike W
I would just tape off the wires so you can go back to the old setup. Just hook the wire like you said. You have to rev the engine to get the 1 wire alt to start charging. I still prefer the stock setup, easy to check and cheap to repair.
Old Oct 19, 2004 | 03:53 PM
4x4Subaru's Avatar
4x4Subaru
You will need to unplug the charging harness, both the three prong and two prong plugs. Might as well put the old charging harness and regulator away on a shelf somewhere.
As far as the wiring. I took the plug with the three wires and ran them all to the hot side of the soleniod. The plug with the two wires. The green one leave dead and the yellow one goes to your horn. Run a heavy guage wire from the hot side of the solenoid to the one post on the back of the ONE-WIRE alt. Also for safe measure ground the alt with the a heavy gauge wire.
If you email me I have some pics. Greg
