1978 - 1996 Big Bronco
91 crown vic trans in 88 bronco
Old Oct 17, 2004 | 10:22 PM
john2139's Avatar
john2139
i was wondering if a 1991 crown vic aod trans will fit in a 1988 bronco. I know i have to remover the tail shaft and change it over to the tranfercase. Will this work or is this atempt not worth it.
thanks for all the help
john
Old Oct 18, 2004 | 07:30 PM
dammford's Avatar
dammford
I think there is a differnt gear ratio
Old Oct 18, 2004 | 11:36 PM
greystreak92's Avatar
greystreak92
Dammford has a point. Check the gearing in the Crown Vic AOD. There is almost assuredly a difference considering you are going from a car to a truck setup. If the gearing is different enough you will screw your mileage and performance. But its worth checking into considering the number of Crown Vic's floating around out there with nothing better to do than donate parts to a more worthy cause.
Old Oct 18, 2004 | 11:45 PM
john2139's Avatar
john2139
thanks
thanks guys for the help will look into it
Old Oct 19, 2004 | 01:29 PM
Kemicalburns's Avatar
Kemicalburns
if the gearin is lower go for it. if its higher of course pass it up. but you got the idea already on what needs to be done. What motor is going in front of this?
Old Oct 19, 2004 | 09:14 PM
john2139's Avatar
john2139
there will be a 5.0 in front was toying with the notion of putting a c6 put cant afford the gas as it is 2.40 a gallon. So toying with other things
thanks again guys
john
Old Oct 19, 2004 | 09:39 PM
john2139's Avatar
john2139
found two gearing types reg. and low
1 2 3 4
reg 2.40 1.47 1 .67
low 2.84 1.55 1 .67
i think that the trucks had the low set
any help with this info would be great
thanks
guys
Old Oct 20, 2004 | 11:21 AM
greystreak92
Just a guess but I would imagine you are correct in your assumption about the lower gearing. Would make it easier on the engine moving the heavier vehicle if it was allowed to spin a little harder in the first two gears to help develope the torque to move the truck.
