89 ranger 2.9 choke problem
Old Dec 18, 2002 | 08:03 PM
lilcase108's Avatar
lilcase108
The truck has been sitting almost a year and the electric choke does not seem to be working right. When I go to start it it almost cranks but i have to give it gas to get it started but then it has a very low idle. Can someone please tell me what the ploblem might be and what i need to do or buy to fix it.
Old Dec 18, 2002 | 08:33 PM
mathelm's Avatar
mathelm
I don't beleive they made an 89 2.9 with a choke? OR are you just referring to the way it starts?
Old Dec 18, 2002 | 08:57 PM
lilcase108's Avatar
lilcase108
what I mean buy the choke is the carberated fuel injection.
Old Dec 18, 2002 | 09:46 PM
mathelm's Avatar
mathelm
[updated:LAST EDITED ON 18-Dec-02 AT 10:58 PM (EST)]ahh.. then there is no choke. I'd check the trouble codes, buy a haynes repair manual. Pick up a can of carb cleaner and pull the air filter hose (check the air filter). See how it cranks with the air filter out. Make sure the throttle body is closing all the way. Use the carb cleaner(and an old tooth brush) to clean it. Will probably be black (which is normal) with crud. But if it will run, I'd drive it for a few days before I started changin out sensors (trouble codes) because some of them may just need alittle use after sitting for so long.
Old Dec 20, 2002 | 09:16 PM
tjohnson's Avatar
tjohnson
If you have a 2.9 it is not carberated, I wouldn't use carb clearner it can kill your o2 sensor. they have throttle body cleaner for use on injected motors. sounds like your IAC (idle air control) could be plugged with some junk Check all the tubes coming off your throttle body and clean them out if they need it.
Old Dec 20, 2002 | 11:33 PM
Torque1st's Avatar
Torque1st
Posting Legend
Mdc9966
Sep 16, 2015 11:20 AM
7283-F250
General Automotive Discussion
Sep 13, 2015 10:29 AM
davohilts
Jan 29, 2015 10:08 AM
hivoltj
1978 - 1996 Big Bronco
Apr 10, 2014 11:19 AM
pbuffing
Oct 3, 2005 02:13 AM
