Voltage Regulator Clicking, Voltage Drops
Old Oct 17, 2004 | 03:27 PM
peterjeff's Avatar
peterjeff
i thought the truck wasn't starting because of air in the lines, but when i put a test light on the glow plugs (just to be sure) they would cycle on & off every 5 or so seconds and i was hearing the voltage regulator click. what's happening??
Old Oct 17, 2004 | 05:26 PM
peterjeff's Avatar
peterjeff
Glow Plugs Cycle On & Off
After more thorough observation: CLICK glow plugs on 2 secs. - CLICK glow plugs off 7 secs. - (then repeats)
Old Oct 17, 2004 | 07:30 PM
dieselnovice's Avatar
dieselnovice
There is a relay behind air filter/ air intake. It sound like the relay maybe bad. They are less than 20.00. You can also bypass them if need using a momentary switch to control the plugs. If you look through earlier post they cover how to test the relay and how to bypass if you want
