bushings
Old Oct 17, 2004 | 09:39 AM
dmuncy's Avatar
dmuncy
Question bushings
I have worked on trucks and cars all of my life,but I have never changed
the radius arm bushings on a ford truck.
I have a '84 ford F-150 4x4 351w, long wide bed, extended cab.Looks like quite a job to me.
Can anyone give me some hints?
My old truck is in my gallery.
Old Oct 17, 2004 | 02:39 PM
Scarydecoy's Avatar
Scarydecoy
The radius arm bushings aren't to bad if you can get that front end slid enough forward, even then it's not to bad if you have to drop it. If you decide to go the droping the front end route then do your pivot bushings also real quick. They are a pain to get in and out, but if your truck has high miles like my 84 then it's gonna be ready.
Old Oct 17, 2004 | 09:31 PM
big hoss 29's Avatar
big hoss 29
If you do the radius arm bushings, you could grind the heads off of the rivets on the radius arm brackets and replace them with grade 8 hardware.
Old Oct 17, 2004 | 10:42 PM
Violjohn78's Avatar
Violjohn78
I grinded mine, made the work fairly easy. I had to use air hammer and chisel my grinder would not get in there..You might be able to just use a large chisel and BFG if air hammer not an option. Grade 8 hardware should be used when putting it back together.
Old Oct 18, 2004 | 12:54 AM
mustange70's Avatar
mustange70
Yeah its easier to cut the rivets and replace the with bolts, cause then you only have to unbolt the bracket, take the nut off the radius arm, chang the bushings, and bolt everything back up. One of our old farms trucks that is used from spraying these bushing go out once a year it seems like they need to be replaced and going this route you can change these bushings in at least an hour (start to finish) where the other way can take up to doulbe that.
Old Oct 19, 2004 | 09:17 AM
dmuncy's Avatar
dmuncy
Thanks dudes,Ifeel beeter about it now.I work part time at a car lot and have a lift.
seems like this is the best place to get info.
Thanks
Dave
Old Oct 19, 2004 | 03:23 PM
kohlerjd110's Avatar
kohlerjd110
i have found that it is eayser to remove the nut from the radius arm stud and pull the axle foward with a come-along about 2inches , just enough to slip the bushings in. this way is much faster the grinding the pad off or dropping the axle
