air pump question
Old Oct 16, 2004 | 08:37 PM
omni's Avatar
omni
air pump question
My 1980 f150 has the original 6 cylinder, and I was wondering about the air pump, should I disconnect it? or leave it alone,will it effect the egr? and if I disconnect it how should I go about it? thanks Randy
Old Oct 16, 2004 | 10:15 PM
andym's Avatar
andym
Unless it's frozen, don't even bother. You'll get maybe 1/2 horsepower by disconnecting it. It won't affect the EGR, it supplies fresh air to the cat so it can burn pollutants.
Old Oct 16, 2004 | 10:53 PM
mustange70's Avatar
mustange70
Yeah i would leave it alone till it gives you problems, then i would just disconnect the airlines going to the cat and the filter for the incoming air, but if you can get away with it i would remove the entire assembly and just replace the belt with a shorter one.
Old Oct 17, 2004 | 12:07 AM
omni's Avatar
omni
I noticed a big rubber hose coming from the air pump, that goes to the EGR assembly under the carburator, how would you ever plug that off? actually it seems to be working fine, the reason I ask is I think I have a slight exhaust leak sound coming from the engine compartment, have'nt pin pointed it yet but was suspecting that air pump business
Old Oct 18, 2004 | 12:10 AM
mustange70's Avatar
mustange70
That exhaust leak could be a loose exhaust bolt or something, but if its a his like souond or something similar then just check all the hoses and such for any cracks or rotted spots, mostly likely it'll be around the fitting where the hoses plug into their necessary connections. But if it is working fine i would just leave it alone.
Old Oct 18, 2004 | 06:34 PM
omni's Avatar
omni
Ok
Thanks guys, I'll check it out for leaks, then leave it alone.
Old Oct 19, 2004 | 03:32 PM
kohlerjd110's Avatar
kohlerjd110
when i rebuilt my 300 i took the air pump off and cut that big hose about two inches from the base of the carb , put a bolt in it and a hose clamp. i have had no problems with it. if you do this you also have to plug off the vacume lines that go to it
