Sponsored by: Real Truck
Fog Light Switch
Old Oct 20, 2004 | 10:15 PM
SuperDuty King's Avatar
SuperDuty King
Use a test light to find the hot wire when fogs are on, if light goes out when fogs are switched off, that is the wire you need to jump. I is possable that the picture is reverse image, I didn't check that.
Old Oct 20, 2004 | 10:24 PM
Jokenring's Avatar
Jokenring
The picture is fine, couple of different colored wires is all. The brown wire on the top left of the harness is the same, then mine are spaced one over from there. Bottom config is the same.
