460 on propane
Old Oct 16, 2004 | 10:05 PM
94f2507.3td's Avatar
94f2507.3td
460 on propane
i am planning on rebuilding my 460 and was wondering how i should build it to run on propane. would it get better mpg running on propane ,has anyone ever done a propane conversion?
Old Oct 17, 2004 | 02:47 PM
merc460's Avatar
merc460
I am running my 460 on propane the big thing is get the dist. curved to propane specs, also depending on what heads you are using you may want to install hardened seats. I am using C8 heads with hardened seats and stainless steel valves. Later model heads all ready have hardened seats for use with unleaded gas. Another important area is the ignition I am using a MSD 6al with a blaster coil propane needs a good hot spark. Also heat has a negative effect on the octane rating of propane so cold air intake is important but. and with any engine you need to start with a good motor if your engine is tired or worn out propane will only amplify the problem.
Old Oct 17, 2004 | 04:04 PM
Nigel's Avatar
Nigel
I was about to post this question . I just got a '85 460 out of an f350 today for my 78 f250 project today and CHEAP. I want to rebuild the engine and set it up for propane. It is an offroad rig and needs torque more than hp.
Has any one gone as far as to up the compression to get full bennefit from the propane?
Cams?
What propane carbs work well in this application?
Intake?
Ted
jonnybronco
Bio-diesel, Propane & Alternative Diesel Engine Fuels
Mar 6, 2014 11:27 PM
460jared96
Jan 16, 2014 12:04 PM
77f250400
Jun 11, 2010 07:55 AM
fishindave11
Alternative Fuels, Hybrids & Mileage
Jun 26, 2008 01:18 PM
hmorder
Oct 22, 2003 01:59 PM
