brakes
Old Oct 16, 2004 | 05:27 PM
f-4x4's Avatar
f-4x4
brakes
here is the question...... why are my back brakes locking up before my front ones and im pretty sure ie got my back brakes adjusted right.
thanks for any help
Old Oct 16, 2004 | 06:49 PM
79_250RangerLariat's Avatar
79_250RangerLariat
Are you trying to lock your brakes up?? If so then something might be wrong with your front- lines, calipers, pads, rotors, porp valve. Or maybe your backs are set too close. If not than probably something in the porp valve
Got air in the lines?
Old Oct 16, 2004 | 08:51 PM
f-4x4's Avatar
f-4x4
no air in lines. but i put new rotors, pads, calipers, and new front brake line on to day also i converted from no power brakes to powerbrakes, althought the problem was there before i did all that
Old Oct 20, 2004 | 02:21 AM
CameronAdams's Avatar
CameronAdams
Rear Brake Lockup
Take a look at the proportioning valve. I had the same problem. Replaced the valve with a new one, and 20 minutes later I was all set....
Good Luck! Cameron
1977 F250 400 (X2)
1999 Buell X1 Lightning
Old Oct 20, 2004 | 09:16 AM
73Custom's Avatar
73Custom
Is there any evidence of gear oil on the rear brakes? Sometimes the rear seals leak, allowing gear oil from the differential to get onto the brakes. This will cause them to lock up easily. Must replace the axle seals and replace the shoes.
Marty
Old Oct 20, 2004 | 11:15 AM
f-4x4's Avatar
f-4x4
how do i tell if the valve is bad, and what is that little pin sticking out of the valve
