Mysterious black box...
Old Sep 13, 2002 | 10:44 PM
JMag's Avatar
JMag
About a 2 weeks ago I couldn't start my truck. When I turned the key I heard a clicking sound that I found out was coming from the solenoid. I tried to bypass the solenoid with a screwdriver but I still could not start it. I figured that the screwdriver wasnt conducting well so I replaced the solenoid...still nothing, and made the same sound. Heres the catch-I recently found a switch under the steering column connected to a little black box labeled "Starter Imobelizer". I tried flipping the switch, but still nothing. I then realized that it had wires running to the solenoid, so I disconnected them, nothing. There is a wiring harness running from the box to who knows where that I disconnected also, but still nothing. Could there be a blown fuse?... a computer problem? There are no loose wires and the battery is charged. I was able to pop start it and it ran fine by the way. I am confounded by this problem- Its seems that no power is getting to the starter, and I can only think that this Imobelizer is to blame. Any help will be extremely appreciated since my 93 xlt 4x4 4.0 v6 has been out of commision for 2 weeks and I miss our time together, thanks again.
Old Sep 14, 2002 | 12:07 AM
Mil1ion's Avatar
Mil1ion
Is it possible you have an aftermarket alarm system ?
[font color=red]Dennis
FTE Assistant Administrator
[/font]
[link:www.ford-trucks.com/guidelines.html|Club FTE]
[link: motorhaven.autoanything.com|How YOU Can Support This Site]
http://www.clubfte.com/users/mil1ion/canada_flag_animated.gif
[link:www.clubfte.com/users/mil1ion/Mil1ion.html|My Website,"North Of The 49th"]
Old Sep 14, 2002 | 12:32 PM
JMag's Avatar
JMag
nope, no alarm
Old Sep 15, 2002 | 07:06 PM
Ken00's Avatar
Ken00
[updated:LAST EDITED ON 15-Sep-02 AT 08:07 PM (EST)]Have you checked the battery cables, they corrode inside. That box does sound like something aftermarket but I don't think it's you problem, it just sounds like you are not getting suffient power which causes the solenoid chatter. Have you had the battery load tested?
Old Oct 23, 2002 | 09:19 PM
1offranger's Avatar
1offranger
Check your fuses in your power distribution bow in the engine bay.
Old Oct 24, 2002 | 10:40 AM
PowerRanger40's Avatar
PowerRanger40
Check all the Wires on the starter, there’s usually a small wire with a spade connector there, if you bumped that your truck will not start.
Old Oct 31, 2002 | 07:40 AM
4_6ranger's Avatar
4_6ranger
hey man i know this sounds crazy but tap your starter with a hammer a couple of times then see if it will start if so take of and replace or even check and make sure the ground wires are clean all thats been the biggest problems ive found on some of the newer cars doing this
Old Nov 8, 2002 | 06:14 PM
BGCARLILE's Avatar
BGCARLILE
Post Mysterious black box...
I had a similiar problem on my 93 4 cylinder. Finally pulled the starter itself, took it to Auto Zone for testing. Worked on their test machine but the amps were way low. Put on a new starter and all is well. Suggest you have the starter motor checked. Good luck!
Old Nov 8, 2002 | 06:49 PM
Torque1st's Avatar
Torque1st
Posting Legend
The Starter Immobilizer is an aftermarket anti-theft device. You will need to repair the wiring in your truck. If you don't have the ability to restore the wiring per the schematics for your truck you will need to take it to a reliable mechanic for repairs.
Thanks for using FTE!
[font color=red]As a Moderator I do not "Subscribe" to most topics,
please send email/pm if you need a reply -Thanks![/font]
Old Nov 8, 2002 | 07:21 PM
Matt_W's Avatar
Matt_W
if you are hearing the starter solinoid "clicking" that means the starter circut is functioning correctly at least up to that point. therefore i would not fault whatever that black box is because if that caused the problem i doubt you would have heard the clicking. I would look more toward objects after the solinoid or mainly the starter (assuming your battery is good). It could be a dead spot on the starter motor. But check the connections at the starter motor too. a wire could have come loose somewhere.
Old Nov 8, 2002 | 10:50 PM
rick_mack's Avatar
rick_mack
Same problem with me a couple of weeks ago. Turned out to be a bad connection at the starter.
Old Dec 23, 2002 | 05:26 PM
mutz's Avatar
mutz
I have had the same problem with my '93 Ranger. I don't know what the permanent fix is, but a temporary one is to lossen the battery terminals and move them around a little. It seems as though a little corrossion builds up between the post and the terminal that disrupts the contact. It occurs most often when there is moisture in the air (fog or rain).
Good luck.
Mutz
Old Dec 23, 2002 | 07:01 PM
mathelm's Avatar
mathelm
[updated:LAST EDITED ON 23-Dec-02 AT 08:05 PM (EST)]Come on guys, Think. He shorted the selinoid. So he either has a bad conection at the battery, the starter or the battery, the starter is bad. Don't rule out the starter being bad. So try jumping it off( I really assume you've either tried jumping it off or know your batteries fine). If that doesn't work take the positive cable and touch it to the starter side of the selenoid. If that dosen't work check your cable and connection at the starter. Next step is new starter.
I realize this thread is a couple months old, but some one searching the post may actually want a step by step way to find/fix the problem.
Old Dec 25, 2002 | 04:34 PM
Torque1st's Avatar
Torque1st
Posting Legend
Old Dec 26, 2002 | 02:47 PM
amp17757's Avatar
amp17757
In line with several of the prior posts, sounds like the solenoid is OK. Like "mathelm" said, shorting across the solenoid pretty much ruled that out. The idea of corrosion at the battery is THE FIRST THING TO CHECK EVERY TIME! After cleaning the battery connections, lube the posts & terminals THOROUGHLY with a grease designed for that purpose, to slow the rate at which corrosion occurs in the future. In reference to "4_6ranger" suggestion to tap the starter ... believe it or not, I too have had that happen. I had to tap the starter with a hammer while my wife held the ignition switch in the start position every time, until we had time & bucks to replace the starter. Also, how old is the battery?? The battery can be putting out enough juice to power everything, as though normal, but NOT ENOUGH to crank the starter. That WILL cause the clicking solenoid every time you try to crank. And also as mentioned, the connections at the starter itself. Clean them just as you would the BATTERY connections. This is all reasonably simple, & cheap or free stuff to cover before going into the more involved, & maybe costly stuff. Yes, this thread is a number of months old. Have you had any luck??? Should be a very simple thing to fix.
