1978 - 1996 Big Bronco
turns, doesn't start
Old Oct 16, 2004 | 04:52 PM
Broncoboondocker's Avatar
Broncoboondocker
I have an '88 302 that turns over, but no start. I've replaced the TFI, coil, and ignition switch. No fire from the coil. It has been sitting a while-- about 2 years-it was running, but when the TFI would heat up, it would die and wouldn't start until it cooled off. This problem started after I replaced the TFI--the new one was tested and tests ok. I am at a loss as to where to look next.
Old Oct 16, 2004 | 10:52 PM
BroncoRoadKill's Avatar
BroncoRoadKill
Have you checked the pick up coil inside the distributer?
Old Oct 17, 2004 | 01:16 AM
COBRAjrb's Avatar
COBRAjrb
did u wipe the dielectric grease on the tfi?
Old Oct 17, 2004 | 12:35 PM
BroncoWY's Avatar
BroncoWY
Is it getting a spark? Could be fuel pump too. Mine would die intermittently then start back up a few hours later after getting towed. No fault codes. Check the inertial switch and the fuel pump pressure.
BMW2
May 21, 2014 01:03 AM
mxhowes1
Nov 11, 2011 08:39 PM
Jrod13
15
Aug 3, 2007 06:40 AM
TomH5898
May 16, 2007 06:39 PM
Snook
Jun 17, 2003 09:12 PM
