Fire from rebuilt carb ???
Old Oct 16, 2004 | 04:03 PM
1985ColumbusF150's Avatar
1985ColumbusF150
Fire coming out of newly rebuilt carb upon 1st startup???
I just rebuilt a Motorcraft 2150 for my 76 highboy with a 360 and upon 1st startup, after cranking for a while to get gas to it, it tried to start but fire popped out of the carb. I dont wanna try again now until I find out why that happened? Any ideas?
Tony
Old Oct 16, 2004 | 04:24 PM
ranger429's Avatar
ranger429
It probably just backfired.
Old Oct 16, 2004 | 08:09 PM
teds74ford's Avatar
teds74ford
You may have ruined your power valve, though. I have had that happen a lot. I think timing can cause it, but once the truck is all tuned up, shouldn't happen. I had a few fires. Quite spectacular in the dark
Old Oct 17, 2004 | 01:09 PM
Talyn's Avatar
Talyn
ya, tahts blow back, or to much gas in teh carb i think.
shoudlnt' have had to crank to get gas in there if its a carb.
Old Oct 17, 2004 | 02:38 PM
1985ColumbusF150
could it have been the float?? Today I tried it again and it started but gas flooded all over the engine....a LOT of gas. I think my float is out of adjustment. What do you all think?
Tony
Old Oct 17, 2004 | 03:44 PM
ford390gashog's Avatar
ford390gashog
yeah if gas is flooded the engine your flost is not right what did you sent it at and is this your first rebuild
Old Oct 17, 2004 | 03:55 PM
1985ColumbusF150
well I have rebuilt a single barrel from a 300 inline 6..and had no problems......this is a two barrel 2150 and I did not set the float at all when I rebuilt it. I just let it the same as it was before I rebuilt it figuring it was set OK then cuz it ran. I guess not. I will be messing with it tonight so maybe you can give me some tips.
