Where does PCV valve connect??
Old Oct 16, 2004 | 11:31 AM
1985ColumbusF150's Avatar
1985ColumbusF150
I just rebuilt my carburator and replaced the PCV valve in my 360 engine from my 76 f250 highboy and I cant find where the PCV valve hose goes into? I thought it went to the carburator but there is no hole.
Tony
Old Oct 16, 2004 | 11:34 AM
LxMan1's Avatar
LxMan1
It should go to the carb either under the front or rear of the carb.
Old Oct 16, 2004 | 12:23 PM
Rifleman7.62's Avatar
Rifleman7.62
LxMan1 is correct. Check the vacume hoses that go into the base of the carb as someone may have hooked up the wrong one so there is no hole left. When I bought my 79 it had the crankcase vent hooked up to the pcv inlet on the carb instead of to the air cleaner. Some people unhook stuff and put where it don't belong when reassembled. Just something to check.
Old Oct 16, 2004 | 03:11 PM
1985ColumbusF150
thanks for the replies. I am going to work on it later tonight.
Old Oct 16, 2004 | 10:10 PM
ford390gashog's Avatar
ford390gashog
it goes in the back left hand corner of the carb
Old Oct 16, 2004 | 10:37 PM
1985ColumbusF150
ok, but I'm still kinda baffled because the hose has a metal end fitting and the only openings in my carb back there are metal too. They dont accept metal hoses. The hose off the PCV valve is metal and only goes to a certain area so it HAS to go somewhere back there....I wish I had a diagram of where it goes so I can examine and compare it to my carb.....
Old Oct 17, 2004 | 09:56 AM
alcan60283's Avatar
alcan60283
you're right, your carb doesnt accept a metal hose! you need to put a small section of rubber off the PCV line to go onto the carb. That should solve your problem.
Old Oct 17, 2004 | 11:02 AM
1985ColumbusF150
There is a 1/4 inch hole in the back of the carb that was capped off when I got the truck? Could this be for the PCV valve hose?? It is directly in the back at the bottom. Also, there is another smaller opening towards the top of the carb in the back also. It has been capped as well. Anyone know what that is for?
Old Oct 17, 2004 | 09:38 PM
LxMan1's Avatar
LxMan1
The bottom one is for the PCV, just use a short piece of hose to hook up the metal line to the carb. The top one probably went to the choke to help pull warm air into it.
Nes0129
Aerostar
13
Jul 11, 2015 01:31 AM
rth1
Mar 9, 2005 02:21 PM
irishman200232
Feb 8, 2004 06:26 AM
Webslinger
Oct 5, 2003 12:46 PM
BrianJ77
Aug 15, 2003 09:45 PM
