Gauges
Old Oct 16, 2004 | 10:10 AM
satcom40's Avatar
satcom40
Question Gauges
Ok I got the Perdator, remote start,and geting the pre-luber, and will upgrade the exhust when I save some more money. So what gauges will I need. Thanks
Old Oct 16, 2004 | 03:05 PM
okeefl's Avatar
okeefl
http://www.dieselmanor.com/gauges/gauge_kits_psd.asp
Old Oct 16, 2004 | 08:06 PM
Daryl Hunter's Avatar
Daryl Hunter
Pyrometer, boost, and tranny are nice. Check out the X-Monitor, it is a digital gauge that has all three in one compact unit. Mounts on the A-pillar and doesn't require removal of the handle.
Old Oct 17, 2004 | 06:49 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Daryl do you have a photo of the set-up...as viewed from the drivers postion.
Old Oct 17, 2004 | 09:54 AM
Daryl Hunter
No, but I'll take some today and post later tonight.
BTW, the gauge comes in black and I was going to buy the matching interior paint but after looking at it for a while I decided to leave it black.
Old Oct 17, 2004 | 10:14 PM
Daryl Hunter
Pics are now loaded in my Gallery. There's one close up and one that shows the dash, pillar and so on.
Daryl
Old Oct 18, 2004 | 06:25 AM
IB Tim's Avatar
IB Tim
I am sure happy you posted the pic. It really does look good and is smaller than I thought...Thanks
Old Oct 18, 2004 | 08:51 AM
Daryl Hunter
The display is quite easy to read, and the intensity is adjustable. It would be kind of nice if it were able to be hooked in to the truck's dimmer but I don't think that this can be done.
It is a digital display so you do actually have to focus on it to read it as opposed to an analog display where you can read the relative position at a glance.
Back to the plus side, it saves the max value reached for each of the three metered items and also flashes if you exceed a user defined alarm threshold. With the optional CES module installed you also have an audible alarm in addition to the blinking display.
I set mine for 1200 deg F so that I'll know that I'm heading into high temps that require more attention. Its only hit that twice, once while towing and once with the SCMT on high performance tune during a sustained hill climb/speed run.
Old Oct 18, 2004 | 10:20 AM
moebdick's Avatar
moebdick
Daryl, how does it attach to the pillar? Also, how big are the "guts" to the display unit? I was pondering how to do an in-dash installation, maybe in the cubby hole or somewhere, fabricating a faceplate that would fit the shape of the cubby. Would the guts of the display fit in that small of a space?
Old Oct 18, 2004 | 03:05 PM
satcom40's Avatar
satcom40
So I haven't got the meter yet but where do you mount the Thermocoupler for pre-turbo temp.
