2001 ranger edge 4+4
Old Dec 28, 2002 | 09:54 PM
garr02's Avatar
garr02
I bought a ranger a couple of weeks ago and iam having a problem.The problem is that their is a rattling noise i think is coming from the driveline.The noise starts when truck is warm and i have traveled more than about 5 miles and going above 50mph.The dealer replaced driveshaft,but no luck.I hope maybe someone has some ideas.thanks
Old Dec 29, 2002 | 12:42 AM
Torque1st's Avatar
Torque1st
Posting Legend
Exhaust system?
Thanks for using FTE!
[font color=red]As a Moderator I do not "Subscribe" to most topics,
please send email/pm if you need a reply -Thanks![/font]
Old Dec 29, 2002 | 11:26 AM
garr02's Avatar
garr02
I don't think so, sounds more like a chain rattle.Does the transfer case have a chain?
Old Jan 1, 2003 | 12:42 PM
garr02's Avatar
garr02
help
Old Jan 1, 2003 | 12:58 PM
1956MarkII's Avatar
1956MarkII
You say the noise doesn't start until the vehicle has warmed up. I gotta think exhaust system, too, especially the heat shields. Rangers/ Explorers are notorious for loose heat shields, which when loose rattle something terrible. I'm no expert, but I can't think of anything in the driveline that would start rattling due to heat. Again, it's gotta be due to heat because it doesn't do it when it's cold, right?
Old Jan 1, 2003 | 03:02 PM
garr02's Avatar
garr02
It only makes noise when going above 50 mph.I think maybe a bearing in trans or front end.
Old Jan 1, 2003 | 05:49 PM
Ken00's Avatar
Ken00
What engine do you have, the OHC 4.0s are known for the chain noise.
Old Jan 1, 2003 | 05:56 PM
garr02's Avatar
garr02
have turned truck off while going down highway and it still makes the noise.
Old Jan 1, 2003 | 06:06 PM
Ken00's Avatar
Ken00
Did you have it in neutral/clutch in? I'm thinking rear gear noise.
Old Jan 1, 2003 | 06:09 PM
garr02's Avatar
garr02
truck in neutral and key turned off
Old Jan 1, 2003 | 06:15 PM
Motorcraft's Avatar
Motorcraft
repack the bearings. Check fluids in the axles T-case.:-)
Old Jan 1, 2003 | 06:18 PM
garr02's Avatar
garr02
fluids are full. Repack wheel bearings? cv joints in front
Old Jan 1, 2003 | 07:15 PM
Torque1st's Avatar
Torque1st
Posting Legend
Old Apr 27, 2004 | 11:11 AM
LtRdNate's Avatar
LtRdNate
Just a thought.....I beleive that the auto transmissions have venting on the top side near the floorboard in your truck. It will make SORT OF a rattle noise when under a lot of torque. If you really get on the gas, you will hear it, but if you gently accelerate, you won't hear it. If you kick down a gear and put alot of torque you will hear it. I talked with a ford veteran, and he said thats what the noise is, and its really nothing to be concerned about.. This is assuming that this is the noice you hear. I have an 01 ranger and I have that noise under torque. My Brother also has the same truck with only 24K on it and it makes the same exact noise.......for what its worth.
Old Apr 28, 2004 | 09:19 PM
valo's Avatar
valo
I have a 2001 4.0sohc. The only rattle i have is the timing chain noise but thats only when its cold
