Sponsored by: Kumho
bleeding brakes
Old Oct 15, 2004 | 02:10 PM
germanshepard's Avatar
germanshepard
bleeding brakes
I have a f-150 2 wheel drive, i just replaced the rear driver brake line. first of all i can not get the tires off truck, itook off lugs , is there something im missing. any help for finding bleeder valve or screw?
Old Oct 15, 2004 | 03:57 PM
moebdick's Avatar
moebdick
You don't need to take tires off to bleed the brakes, although I can see why you'd still wanna be able to do so if you ever had a flat or something. Not sure what you mean by "itook off lugs" though.
On my '90 F150, the bleed nipple is on the top of the back plate, just above where the brake line connects (over the axle).
What year is your truck?
Old Oct 15, 2004 | 04:11 PM
gatesj's Avatar
gatesj
The best way to get the wheel free is to run a oxyacetylene torch with a cutting head on it around the bolt circle for a few seconds on a real high setting. This is if it's a steel wheel. The wheel expands and the drum doesn't, and it breaks loose so nice. Sometimes they even pop when they come loose.
Like he said, the bleeder is easy to get to without taking the wheel off. If you have a few extra bucks look at motiveproducs.com. I have nothing to do with them except being a very satisfied customer. I can bleed out brakes 100% in a couple of minutes with this and it's not that expensive.
Old Oct 16, 2004 | 08:05 AM
germanshepard
Thumbs up
Thank you for your help, I found the bleeder connection and everything worked out well. I will take you up on your advice regarding the cutting torch,that sounds like the easiest way.
wolfrace
Sep 24, 2020 07:27 PM
jake_c_19
Jan 11, 2014 06:54 PM
budden
Nov 1, 2013 07:14 AM
swampfire79
Apr 29, 2013 04:56 PM
neilc88
Jan 14, 2011 06:11 PM
