Brake controller
Old Oct 14, 2004 | 09:57 PM
SHANE_2's Avatar
SHANE_2
Brake controller
Where are all of you guys mounting your trailer brake controllers on your trucks with captains chairs and flow through console? I don't see any GOOD spots.
Shane
Old Oct 15, 2004 | 04:15 AM
keith Ruge's Avatar
keith Ruge
Im in the same spot I think too the left of the stearing wheel about where your knee is .? Shane what Brake controller did you get ? I took the old one off my old truck when I got my new screw and I cant us it the harness has 5 wires and the old controller has 4 Thanks
Old Oct 15, 2004 | 07:26 AM
SHANE_2's Avatar
SHANE_2
I haven't looked at that yet, But I too pulled my controller out of my Superduty and haven't yet installed in the new truck yet. I just pulled the trailer for the first time last night. I am not happy at all!!! My empty car trailer squatted my truck I'd say almost 2"!!! Time to order air bags today. That's a whole new post though......lol
Shane
Old Oct 15, 2004 | 08:20 AM
goatdriver's Avatar
goatdriver
How hard is it to put in a controller? Are the wires and harness already there? Does the power run back to the trailer through the wiring harness for the lights?
Sorry, but I am ignorant about trailer brakes.
Old Oct 15, 2004 | 08:27 AM
GeorgeFX4's Avatar
GeorgeFX4
I use a Prodogy from Tek (something or another). I mounted it on a metal plate under the dash on the left side of the steering wheel. I also got a Ford connector with it. It just pluged right in. No issues and no problems. I have a FX4 and I'm impressed (for a gas truck) with how it tows my car. When I hook up the trailer, the rear end does go down a little, but it only makes it level.
George
Old Oct 15, 2004 | 12:26 PM
sprintcarcrazy's Avatar
sprintcarcrazy
Same here, tekonsha prodigy, they are plug and play, just order the ford harness and it plugs in under the dash. Mine is mounted on the metal plate left side under dash too.
The Prodigy is about $99.00, but once you set them, they are set. And it only takes about 2 minutes to set or less.
Old Oct 15, 2004 | 12:47 PM
Genesdsu's Avatar
Genesdsu
I got prodigy and mounted it under the dashboard as far right as I could right above the gas pedal. These is a bracket there that fit perfectly and I can easily see it and get to controls.
Old Oct 15, 2004 | 01:11 PM
Steina's Avatar
Steina
CO River Rat
Keith -
One of the harness wires (black, I think) is for running lamps; you shouldn't need it for a 4-wire brake controller.
Steve
Old Oct 15, 2004 | 02:08 PM
keith Ruge's Avatar
keith Ruge
Steina , Thanks but wright after I threadid I went too the Net @ ordered the Prodigy I think I got a good deal so about a weak I think Ill do wright
Old Oct 15, 2004 | 02:16 PM
Steina's Avatar
Steina
CO River Rat
Keith -
I also use the Prodigy - it's an excellent controller. Hopefully, you also ordered the plug-in harness; it makes the install go quick and easy.
Steve
Old Oct 15, 2004 | 02:19 PM
5_labsownus's Avatar
5_labsownus
I like the tekonsha prodigy, I have one in both trucks and they are easy to set.
Old Oct 15, 2004 | 02:22 PM
goatdriver's Avatar
goatdriver
so you buy the prodigy and the harness and plug it in. then you plug in your trailer wire at the hitch, and your done? This seems too easy!!
keith Ruge's Avatar
keith Ruge
I didnt order the harness becouse it was 3 yes THREE Ft. long not any shorter so Im gona go with what I got with the towing package
Old Oct 15, 2004 | 02:25 PM
Steina's Avatar
Steina
CO River Rat
GoatDriver -
If your truck has the towing package with a 7-pin connector by the hitch, all you need is to mount a brake controller. Make sure you get a plug-in harness when you buy the controller. The hardest part is mounting the bracket for the controller. Good luck!!!
Steve
Old Oct 15, 2004 | 02:32 PM
Steina's Avatar
Steina
CO River Rat
Keith -
When you wire up the Prodigy, follow the instructions and NOT the wire colors 'cause they don't always match.
Steve
