hard starting 7.3
Old Oct 14, 2004 | 05:20 PM
overeasytoy's Avatar
overeasytoy
hard starting 7.3
When hot my friends 92 7.3 Non turbo wont start. Any ideas?
Old Oct 14, 2004 | 06:31 PM
bilder12's Avatar
bilder12
it wont start at all or has a hard time starting? Please provide as much info as possible. Dont let your friend crank on the starter too long, they are sensitive - like me and Malcolm.
Old Oct 14, 2004 | 11:33 PM
overeasytoy
Really hard. He uses starting fluid if it does not want to go. Then it fires right up. Cold it starts like most diesels.
Thanks
Old Oct 15, 2004 | 06:10 AM
pnose's Avatar
pnose
Sounds like injection pump is on the way out,that is the way mine acted before i replaced it.If you must use ether(although i dont recomend it) make sure the glo plugs have stopped cycling or you run the risk of blowing the crap out of the engine when the ether hits the hot glo plugs igniting it.After the gp's have been disconnected or have stopped cycling,with someone cranking the engine give it a small shot of ether,(1/2 second or less)it should fire right up.
Old Oct 15, 2004 | 10:09 PM
banks7.3's Avatar
banks7.3
don't use either - get a can of wd-40, works just as good and won't damage your motor
Old Oct 16, 2004 | 12:07 PM
pnose's Avatar
pnose
I thought they changed the propellant in wd40 from propane to co2 and it didnt work any more
Stephen e
Feb 11, 2015 05:04 AM
powerstroker250
Jun 16, 2014 01:52 PM
GeorgiaBoy17
22
Feb 19, 2014 09:00 AM
Brady Miclos
Nov 9, 2012 12:57 PM
SVLERF250PWRSTRKE
Nov 3, 2007 11:01 PM
