SERIOUS PROBLEM...PLEASE HELP
Old Jan 12, 2003 | 12:32 PM
WXboy's Avatar
WXboy
Guys, the temperature dropped to 13°F here last night for the first time this winter. When I started my Ranger, the "Check Gage" light came on and I noticed the oil pressure gage was at the extreme low end, not moving! It said I had zero oil pressure. I was scared to death! I left the truck parked and idling to see what would happen when it warmed up. After a few minutes, the gage came back up to normal. But what is wrong with my truck? Bad sending unit? Bad gage? Or is it really not getting any oil pressure?
Thanks. :-(
Old Jan 12, 2003 | 01:12 PM
mrwizard's Avatar
mrwizard
What weight of oil do you have in the engine, and are you sure it's full? With that kind of temperature, 5W-30 is probably about right.
Old Jan 12, 2003 | 01:49 PM
redline1's Avatar
redline1
May want to consider switching to synthetic oil as it doesn't thicken like conventional oils in cold weather or install a block heater.
Old Jan 12, 2003 | 03:30 PM
greenpus's Avatar
greenpus
Bad sending unit. This is very common in these trucks
Old Jan 12, 2003 | 03:37 PM
WXboy's Avatar
WXboy
Yeah, I had 10W-30 in it, but I changed the oil today and put 5W-30 back in. It still has the same problem though...when I first start it up cold, it says zero oil pressure. And then after a few minutes the needle will suddenly jump into the normal range. It doesn't gradually go up, it just jumps to the middle of the normal range on the gage. So I'm hoping it is just a sending unit. From what I can see in the Haynes manual, this unit is located on the driver's side of the oil pan. Is that right? Will I need any special tools to replace it?
Old Jan 12, 2003 | 04:42 PM
TOUGHLover's Avatar
TOUGHLover
fordopie
Mar 29, 2012 09:08 AM
hasbeen
Nov 2, 2003 10:36 AM
Col Flashman
Oct 14, 2003 04:21 PM
heshmastr
Modular V10 (6.8l)
Mar 15, 2003 10:19 AM
Chris Rogers
Jan 17, 2001 10:45 PM
