fuel pump trouble
The trouble is that I have a clear fuel filter, and when running, the fuel trickles in, even when the rpms are up, and I think it is causing a lean condition.
i've run new lines the whole way back to the gas tank; however, they are rubber gas line hoses.
what I am wondering is it those feed&return pumps has a diaphram in them that will leak the gas back the return line when the truck is running if there is a hole in it? I haven't noticed any gas in the oil, but I really haven't smelled the dipstick.. This is a project truck, so it has been run once in a while for the last couple years.
I don't really want to replace the rubber lines with steel (as it sucks to bend) and I really don't want to use braided stainless if I don't have to (I'm not actually sure how to connect it to the factory '85 sender, and it is $$$$$$).
any clues?? I have also thought about switch over to a carter electric pump so I am pushing through line, instead of pulling.1
Sometimes too much information causes unnecessary concern. Clear fuel filters fall into this catagory. They will have a "bubble" or appear to be partially filled much of the time. I am told this is normal. If the motor runs OK I would consider ignoring the amount of fuel in the filter. I have a clear filter on my truck and had the same concerns you do. After I read that a "bubble" is normal, the truck seems to run much better. ( I quit worrying)
if a trickle is normal, that is cool... if not, I want to fix it
Based on the additional information, it sounds like you may have a problem. My clear filter varies from being full of fuel to a fairly large bubble. (Just describing this for information purposes.) Since you are having symptoms that may be fuel starvation related, your concern is valid. Hopefully others who see this topic can offer some advice. I have no experience with your system ,so can't help. (too new for me!)
