Fuel Pressure/ Pump problem
Old Jan 13, 2014 | 08:17 AM
Wbruiser2's Avatar
Wbruiser2
Just when I think I got all the bugs worked out something else happens. I discovered/ uncovered a new issue after getting my 570cfm Holley SA tuned (which is new) and timing set. Truck really runs good so I took it out on the road, found a straight stretch and floored it. It climbed up to around 90 pretty quick and then all of sudden felt like a governor kicked in. I let off the gas for a second and then it would take off. Floored it again and got back up to 85-90mph and it did it again. Let off the gas and then it started acting like it was running out of gas (which I assume the carb did) for about an 1/8th mile then it was back to normal as long as I drove it normal.
I have a new sending unit, new rubber hose to the metal line (not new) to a new rubber line to a clear filter, to a new rubber line, to a new fuel pump, to a new rubber line line to a regulator, new line to the fuel pressure gauge on the metal line to carb (that is setting on an Edlebrock 289 performer intake). Before I put the regulator on the gauge would read between 3 to 13. After I put the regulator on it reads 0 (set on 5.5). The clear filter doesn't fill all the way either but the clear sight window on the carb always shows fuel when I look at it.
Has anyone had a similar experience and fixed it? A clear filter is probably not a good idea but wanted to use one so I could see the fuel until I got it tuned, but other than that, is there anything wrong with my set-up as I described? Or is it something with the dura spark ignition (new ICM, distributor, and MSD Blaster coil) that just won't handle it? I didn't notice what the RPM was when it happened but it runs about 3k at 65mph..
Old Jan 13, 2014 | 08:49 AM
jason77F250's Avatar
jason77F250
It's Alabama's Department of Public Safety way of telling you not to drive like a wild man.
PS Roll Tide!
Old Jan 21, 2014 | 07:47 AM
Wbruiser2's Avatar
Wbruiser2
This is what I learned: The Spectre Fuel regulator is a piece of crap. I took it off and installed a glass cased filter in it's place and removed the plastic clear filter. No problems for now
azroxx
13
Dec 16, 2018 06:46 PM
cubanice27
Nov 5, 2015 06:39 AM
Mudman
Dec 17, 2005 08:25 PM
jpmiller
Oct 15, 2004 06:56 PM
archangel
Aug 24, 2003 11:23 PM
