Which Power Steering Box
Old Oct 13, 2004 | 05:37 PM
66 4x4's Avatar
66 4x4
Hey ,need Info For My 1966 F100 4x4 Shortbed ,i Purchased A 1979 F-150 4x4 Power Steering Box And The Mounting Holes Are Off And Dont Know If Steering Tie Rod Will Mount Up.if Any Body Knows Another Box That Will Fit Better Let Me Know And I Will Sell This One On Ebay And Watch For The Right Box On Ebay.thanks For Any Info.
Old Oct 13, 2004 | 08:05 PM
daggerNC's Avatar
daggerNC
Alright - I'm just learning about these trucks but I believe your PS box will work/is correct but you need the left side (driver side) engine mount from the PS donor with same type engine (FE in your 66?). If you do have a big block then you need to look for a donor mount up through 76 as that was the last year big blocks were available. You will then notice that this mount uses a different mounting hole (one closer to towards the radiator). With that in place the '79 PS box should then bolt in.
I'll let the experts here validate this........
dagger
Old Oct 14, 2004 | 06:01 AM
jowilker's Avatar
jowilker
David, the 4x4 stuff is a whole nother country.
John
Old Oct 14, 2004 | 06:27 AM
FordBoypete's Avatar
FordBoypete
Smile
AHyuuup! Even a different Zip Code & language too.
Reason is, 4X4's are "Front steering", meaning linkage is in front of front axle housing & differential so drive shaft will be clear & not intefered with. FWIW David, the 4X4 Strg gear is a whole different animal and it also matterwhether it's leaf or coil spring front suspension too. . . .
You're right for 4X2s like we have.
But as John points out the 4X4's are a whole different deal.
check your E-mail
FBp
Old Oct 15, 2004 | 01:22 PM
mstolz's Avatar
mstolz
Question 65 Ford F100 4X4 Power Steering
I'm trying to exactly the same thing. I'm looking to convert my manual steering to power. Does anyone have any information on what it takes for a 4X4?
Old Oct 15, 2004 | 01:40 PM
mstolz's Avatar
mstolz
Talking 65 Ford F100 4X4 Power Steering
I guess I should add that my truck is a stick shift, Not on the column!
Old Oct 15, 2004 | 02:27 PM
skonnie-mark's Avatar
skonnie-mark
There are a couple articles int the Tech section on doing the swap in '70's trucks, may be some useful info there.
Old Oct 18, 2004 | 09:24 AM
daggerNC's Avatar
daggerNC
66 4x4 - sorry for the wrong info (I'm in the process of learning all the variances of these slicks). John and FBp will steer you straight and keep me honest
Old Oct 18, 2004 | 04:30 PM
mstolz's Avatar
mstolz
Thanks for the info. I did check out your reference to the tech page and wondered if a 66 would work as well. I would love to find a complete parts list that someone has used like https://www.ford-trucks.com/forums/a...x.php/t-288043
Also does anyone know if you need special privleges to search the forums? I keep getting an error saying I can't.
Old Oct 19, 2004 | 01:40 PM
64ford4x4's Avatar
64ford4x4
steering
You need a box from a 78 or 79 full size bronco as they are front steer.
Old Oct 19, 2004 | 02:27 PM
bocephus_3349's Avatar
bocephus_3349
hey 664x4 i also have a 66 4x4 f-100 i have 6 inchs of lift with 35's so im in need of the pwr steering. the problem i alway run into is. My steering box is on the outside of the frame. Some old bronco's 76-79 run on the out side of the frame and you can by a gear from checker or auto zone. The problem is the way the pitman arm points i.e. to the front or rear of the truck. So i have yet to find any thing on this website to address my problems
Old Oct 19, 2004 | 05:16 PM
66 4x4's Avatar
66 4x4
hey bocephus,your right about the left side,the 1979 box is also on the left.WHATS BAD ABOUT THESE SHORT BED 4X4S IS THAT WAS THE FIRST YEAR FOR COIL SPRINGS AND SOME PARTS ARE HARD TO BUY OR CHANGE,BECAUSE 1967 THEY MADE SOME CHANGES.I DONT KNOW IF THE BOLT PATTERN IS THE SAME ON THE BRONCO.THANKS
Old Oct 19, 2004 | 06:05 PM
Jigsaw's Avatar
Jigsaw
I have a complete P/S setup from a 78-79 Bronco. I think the rotation of the box would have to be reversed to work on a F100 4x4.
Old Oct 26, 2004 | 07:29 PM
bertha66's Avatar
bertha66
bertha66
Hello, I'm new to this site, I did use a box off a 87 toyota 4x4 with a ford pump. It mounted in the same loacation as the ford with a little work
Old Oct 27, 2004 | 11:16 AM
bertha66's Avatar
bertha66
bertha6
I have a 1966 F-100 4x4 with a 390 engine. I used the 87 toyo power box, had to drill and tap new holes in the frame and notch the frame at the crossmember for the pitman arm. I then used a section of a draglink off a mid 80's Chev truck, the hole in the chev fit the pin on the Toyo box, it was grafed on to the stock ford with a left right turnbuckel. The system has worked real well now for 2 years.
