Headunit(Stereo) Removal in 2003 Expy
Old Oct 13, 2004 | 12:24 PM
cmil1's Avatar
cmil1
I did a serach and couldnt find anything about this but I need to know about removing the headunit of my 2003 Expy. Has anyone done this on their own? Do I have to remove the entire brown part of the dash to get it out? Do I need the stereo pulling tool to get it out? Any comments regarding this would be helpful. I need to pull it to install the wired FM for my ipod. IF you have tips or trick the installation of the FM is very easy but the removal of the headunit is the touble.
Thanks
CM
Old Oct 13, 2004 | 03:22 PM
jrgreen's Avatar
jrgreen
yes you need to remove the whole section. I started by removing the two philips screws above the instrument cluster, then pry up around the edges. I disconnected all of the switches that were attached to the plastic i.e., the headlight switch, the 4x4 switch. My head unit(nav system) was held in by 7mm screws. Just take them out and pull, the unit should slide right out.
Old Oct 13, 2004 | 07:39 PM
Shaggy29's Avatar
Shaggy29
FYI - it is the same without the Nav system
Pretty easy to do
Old Oct 14, 2004 | 09:53 PM
Russell B's Avatar
Russell B
Be sure to place the shift lever in low to allow enough clearence to remove the panel.
BaggedMerc
Feb 9, 2016 08:50 AM
berry1234
Jun 9, 2015 05:22 PM
fsupeej22
Jan 11, 2005 10:49 PM
conn110
Apr 21, 2004 11:59 PM
Grimolfr
Oct 21, 2003 08:31 AM
