Vacuum Lines
Old Oct 13, 2004 | 12:05 PM
Arvin J.'s Avatar
Arvin J.
Vacuum Lines
What is used to replace the vacuum lines that get brittle and crack. Dealership prices are exorbitant. I need to replace vacuum line to the EGR valve. Any suggestions? Thank you in advance for you help.
Arvin J.
Old Oct 13, 2004 | 01:20 PM
guzzler96's Avatar
guzzler96
Arrow
I have used some black hose of the proper diameter on mine. You lose the color coding, but it works. Guy at the dealer told me to do that. If there are kits available though, other than dealer or something, that would be nice.
Old Oct 13, 2004 | 06:54 PM
f2504602wd's Avatar
f2504602wd
Vacuum Line Source
I just did the same thing on my '88. You can get bulk black vacuum line at your parts store. I got mine at Advance (Discount) auto parts. It is not formed like your OEM stuff but performs the correct function. Maybe with some inginuity and heat from a blow drier or heat gun you can form it into OEM or other interesting shape. Good luck.
Old Oct 13, 2004 | 07:56 PM
Twitche's Avatar
Twitche
If your going for a cool look, order the colored vacuum hose from jcwhitney.com. They are fairly cheap and look clean.
Old Oct 13, 2004 | 10:21 PM
Ed Bamba's Avatar
Ed Bamba
Haven't check with the local NAPA store but here is a link to one of the products they list on their web site http://www.napaechlin.com/2-671.htm
I don't understand why Ford went with using these plastic vac lines. My Camry uses a combination of rubber and aluminum tubing--if I can find the right size tubing I may adapt it to my truck. BTW, PEP Boys has some small ID rubber hose that I used to splice onto the plactic vac tubes that broke when I was doing some maintenance on the engine.
Nathan J. Hickson
Jan 24, 2017 11:19 AM
Redfridge
Jun 13, 2016 06:54 PM
whateg01
1947 and Older Ford Trucks
Jan 6, 2008 10:22 PM
sausrigging
May 28, 2006 04:46 PM
sholliday
Jul 8, 2005 08:18 AM
