CompCam 292H or something else
Old Oct 13, 2004 | 09:44 AM
pkulaga's Avatar
pkulaga
Has anybody ever run the CompCams 292H? I currently have a 268H but the cam bolt backed out and the dang thing walked on me. Needless to say the lobes aren't looking too good anymore. I was looking into the 292 but was curious if anybody has had any experience with it or it they recommend something else.
390 w/flat tops
CompCams 268H
Edelbrock RPM w/Holley 670
Headmans w/turbo flow's
and custom paint for maximum power
Old Oct 13, 2004 | 11:43 AM
FORD352V8's Avatar
FORD352V8
I would consider the Crane 901 or 941 to be honeset. Dual pattern is best for stock FE heads. I got the 901 and very happy.
Old Oct 13, 2004 | 12:15 PM
rusty70f100's Avatar
rusty70f100
I agree with the 901 or 941, but to fine tune the recommendation we need what compression you're running.
Old Oct 13, 2004 | 12:56 PM
pkulaga's Avatar
pkulaga
compression is 9:1 with hypereutechtics. Out of curiosity, why are you against using Comp Cams? I've heard alot of people complaining about them and rounding out the lobes. Thanks alot guys.
Old Oct 13, 2004 | 02:30 PM
pkulaga's Avatar
pkulaga
Is this the Crane 901 your refering too?
Part Number: 343901
Grind Number: H-260-2 (REPLACES HMV-260-2)
Old Oct 13, 2004 | 04:30 PM
EgoMan's Avatar
EgoMan
Yea thats the one
polcat's Avatar
polcat
I am runnig that Comp 292h cam it performs well, but your compression is to low to run that cam. Comp says it needs at least 9.5 to 1 but reccomends 10 to 1. so if you want to run a bigger cam I suggest ethier th comp 280h or a good crane cam. I preffer Comp myself!! anywasy the comp 292h will not idle very well, not a very streetable cam.
Old Oct 13, 2004 | 05:01 PM
pkulaga's Avatar
pkulaga
sounds good. I'm still not sure of my compression, the machinist I ordered them from said that he thought they were 9:1, but I seem to remember them as 10:1. I will have to find out for sure.
Polcat: You mentioned that the 292 is not a very streetable cam. Is it approaching the limit for the FE engines?
Thanks again for all your help guys I really appreciate it.
Old Oct 13, 2004 | 05:11 PM
polcat's Avatar
polcat
no not by far the limits. It has a very radical racey idle my truck idle around 900 RPM's it just is more for some one that is going to race alot. I have a 390 with 10.8 to 1 compression and runnig this cam. it is very hard to tune in for idle. if your going to do alot of racing I advise it , but if your going to drive on the street alot I would not. especially if you do not have a stall torque converto or 3.75 gears or taller. i am running 4.22 gears and a 2600 stall convertor so it all works great.
Old Oct 13, 2004 | 06:30 PM
pkulaga's Avatar
pkulaga
good deal, I do mostly Street driving, but I need to power for mud racing. I have a 70' F250, 4:10 Dana 60 front and rear, NP435 4-speed. Right now the 268H cam is OK, but as with everything, I need more power for the mud. How do you feel about the 280H? I also checked again on the pistons, they are 10:1 compression, I don't know what my machinist was talking about.
Old Oct 13, 2004 | 08:16 PM
polcat's Avatar
polcat
If youy going to run a comp cam I would suggest either the 280h or the XE284H, both these cam seem to be pretty aggressive especially for what your doing. Look at the @.050 numbers. any cam with a duration of 235 or lower in the @.050 is a good street cam a 235@.050 is just on the edge of streetable but would be a great cam. the 292h cam works good above 3000 Rpm your probably would want a cam that would come in sooner for your mud racing and the street use. Good luck , but one word of warning if your using non-adjustable rockers MAKE SURE you have no more than .040 preload on your hyd lifters!!!
Old Oct 13, 2004 | 08:21 PM
pkulaga's Avatar
pkulaga
Awesome, thanks alot for your help. I'll check the preload and go from there.
hooler1
Feb 14, 2011 07:25 PM
pkulaga
32
Apr 28, 2005 10:29 PM
94F150-408
Dec 29, 2003 08:40 PM
brucen2son
Jan 13, 2003 12:08 AM
LxMan1
May 7, 2002 08:52 PM
