ford tech isc problem
Old Oct 12, 2004 | 08:28 PM
catmech's Avatar
catmech
ok i have a 88 4.9l fi 4x4.i have a ilde problem at start up it wont come off fast ilde until i turn ign key off and restart.then it ildes fine for a while then it goes back to fast ilde on its own.i scanned for codes and got 14.this is the pip failure.not sure what this has to do with the ilde.so i checked the ilde speed control by unpluging it while it was running at fast ilde.it killed the engine.ichecked the omhs at 10.2 i checked the coolant temp sensor at the t-stat and it was 3.92 omh.i dont think its a vacume leak because i can control it sometimes when i shut key off any help?
Old Oct 12, 2004 | 10:15 PM
blumpy's Avatar
blumpy
had this problem with my sons 88 tbird had to change the idle sencer as well as clean the fuel system gumout I used I also hadproblems with his pcv it was spewing oil into the plemuim well I hope this helps
Old Oct 13, 2004 | 06:29 PM
catmech's Avatar
catmech
im not much a fan of a cure in a can.keep them coming any help i can use.
Gary Staves
18
Feb 28, 2017 10:28 AM
speakerfritz
6.4L Power Stroke Diesel
Nov 8, 2016 07:20 PM
antiqbob
Jul 30, 2015 11:32 AM
mr78F150
May 4, 2015 09:32 PM
white 01
Feb 3, 2006 06:58 PM
