How much will it cost
Old Oct 12, 2004 | 04:25 PM
4.9LFord's Avatar
4.9LFord
Cam ?'s - How much will it cost, etc?
I would like to put a new cam in my '95 300, how much would this probobly set me back? And does a a cam add hp/torque, and will it give it a more throaty sound comen out of my glasspack?
Old Oct 13, 2004 | 12:32 AM
optikal illushun's Avatar
optikal illushun
i would say about $200-250 depending on what u replace. u need the cam, lifters, timing cover gasket, side cover gasket, valve cover gasket (may be able to re-use the old one), throttle body gasket and EGR gasket. also, while ur at it i would replace the composite gears with some steel ones from a late 70s f-150 with a 300. they should set u back about $35-40.
the cam i used what the crane power max truck cam, it was $109 from summit, lifters were about $40 and gaskets (cant quote an exact price, i got a master gasket set...)
Old Oct 13, 2004 | 01:30 PM
4.9LFord's Avatar
4.9LFord
did the new cam and lifters etc. help out the power of you 300? and did it hurt the gas mileage.
Old Oct 13, 2004 | 01:35 PM
optikal illushun
well in my old engine it definatly helped in the power dept. gas milage always sucked for me so i cant say. havent driven the truck much since the new engine so i cant say...
Old Oct 13, 2004 | 01:39 PM
4.9LFord's Avatar
4.9LFord
did you install your cam yourself or have it done somewhere? I'm wonderin if it'd be hard to do with the efi and everything, i dont wanna end up breakin somethin and haven to spend more money to just get it runnin again.
Old Oct 13, 2004 | 02:47 PM
thecowboy's Avatar
thecowboy
if you know your bacics, you should be able to do it.although their might be somthing a little diff. about the efi. mines a carb
Old Oct 13, 2004 | 03:31 PM
4.9LFord's Avatar
4.9LFord
i'm just debating on whether to go with the new cam, or to put in 3.55 gears.
Old Nov 9, 2004 | 06:49 PM
txfordboy19's Avatar
txfordboy19
in response to how hard it would be to install your new cam if you get a haynes manual from autozone or oreilly it will tell you step by step how to remove the cam.
