Predator Question
Old Oct 12, 2004 | 01:36 PM
redneck93375's Avatar
redneck93375
Predator Question
I am unable to search right now so I will post this question on the board. I am looking to buy the diablo predator. I have heard you need aftermarket exhaust to run the highest setting? Is this true? I have an 04 F-250 4wd Fx4 and I do very little to no towing. So if I do not tow anything is it okay to run at the hightest setting?
Kenny
Old Oct 12, 2004 | 01:39 PM
Eric Brooks's Avatar
Eric Brooks
You will need an exhaust kit, and a pyrometer to monitor exhaust temperatures, and to keep from burning up the turbo. This is mandatory for running the Predator in the highest setting.
Old Oct 12, 2004 | 03:45 PM
jdadamsjr's Avatar
jdadamsjr
I concur with the upgraded exhaust - or at least remove the restrictive stock muffler...
but I've been running the predator for about 20K miles and no problems....
Old Oct 12, 2004 | 03:50 PM
redneck93375
Is the pyrometer a difficult install. I saw the set of gauges on motorhavens website, but have been weary of buying them because I don't know exactly how to intall them. Do they come will good detailed instructions?????
Old Oct 12, 2004 | 04:28 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Finally someone how believes in gauges….
Old Oct 12, 2004 | 08:25 PM
AV3Fire's Avatar
AV3Fire
jdadamsjr -
Upgraded exhaust to "run" at the highest setting, Understood.
Can you "test" it out just to see the difference before you get the $$$ for the exhaust? or would you recomend against this.
I have a predator on the way, and would love to do a test run, but keep in the 65 hp mode till I get the exhaust (probably spring)
Thanx
Trevor
Old Oct 12, 2004 | 10:46 PM
Monster Duty's Avatar
Monster Duty
Originally Posted by AV3Fire
jdadamsjr -
Thanx
Trevor
I think you should be alright just to test the 100 hp mode , but I would HIGHLY recommend running an exhaust temp gauge if your running in any mode .
I'm running the Predator in 65 hp mode and have hit 1135 pre turbo degrees.
I was going up a slight grade and holding the throttle 1/2 to 3/4 .
04 F350 CC LB 3.73 with 315/75/16 , stock exhaust and I was empty.
Hope this helps
Old Oct 12, 2004 | 11:02 PM
jdadamsjr's Avatar
jdadamsjr
IF you don't tow....
that's what I did....
The predator surprised me when it first came out ....
(if you look at post 2 and 13 in the Predator thread... I asked one question and then complained to motorhaven for getting the predator to me too soon ! )
I couldn't wait on the gauges and didn't have the cash for the exhaust at the time...
so I did an inexpensive straight pipe in place of the X muffler and ran the predator for a while like that....
but in the X the straight pipe was TOO much droan on the many long trips we take so I got a turbo back exhaust and the combo has worked flawlessly since 1-14-04 when I got the predator....
9 months and about 20K miles without a hitch....
(and I've not hurt anything - and I drive HARD without towing.... )
Old Oct 13, 2004 | 05:51 AM
t_j82's Avatar
t_j82
At least put in the Pyrometer before you put in the tuner. I added the Pyro and then the tuner and wow did my EGT's jump. I then added the exhaust and it helped bring them back in line. I figure if you are going to soup it up you should at least monitor what you are doing to your motor, at least with a Pyro you can let your foot off BEFORE you burn a turbo or do other damage. It was not too hard to install, took about an hour and a half or so. I like to think you can NEVER have too many guages!
Old Oct 13, 2004 | 06:11 AM
AV3Fire's Avatar
AV3Fire
OK, so I'm going to add a pyro gage.......
Looked at motorhaven site......does the gage come complete??
Do I need to peice together what I need??
I am goin to do a homemade collar mount I saw posted here a while back (hope I printed it out!!)
Thanx
Trevor
Old Oct 13, 2004 | 07:52 AM
SBV45's Avatar
SBV45
Having the pyrometer is not a bad idea. Again, you will melt pistons before burning up the turbo. That will cost you more than the replacement turbo.
