I hear a few clicks then nothing. It cranks real slow. I just replaced the battery and battery cables. Also replaced cable from starter relay to starter.
Since you have replaced everything in the system (except ign. switch) replace the starter anyway before winter comes so you won't have to do it lying on the cold ground.
If you have your starter out, grab some jumper cables. hook the positive to batt and to the starter (where the wire goes0 then the ground to batt and press on the body of starter, That should tell you if the starter works.
Thanks for everyones help. I ended up replacing the starter solenoid (which was rusted on one side) and the cable from the solenoid to the starter. Now it starts great. It even starts great after its been running which has always been a problem.
