'79 starter problems
Old Oct 12, 2004 | 11:35 AM
jrfoscue's Avatar
jrfoscue
I have a '79 F150 with a 390 engine and when I try to start it, it cranks a little bit and then quits. Could it be the starter? or solenoid?
Old Oct 12, 2004 | 11:42 AM
79_250RangerLariat's Avatar
79_250RangerLariat
when you say it quits, does it just plain out stop, start clicking, what? Is it cranking fast or slow? Good battery?
Old Oct 12, 2004 | 12:28 PM
jrfoscue's Avatar
jrfoscue
I hear a few clicks then nothing. It cranks real slow. I just replaced the battery and battery cables. Also replaced cable from starter relay to starter.
Old Oct 12, 2004 | 02:08 PM
460me's Avatar
460me
Replace the cable that goes from motor to the frame.Good grounds go along way
Old Oct 12, 2004 | 02:14 PM
jrfoscue's Avatar
jrfoscue
I am replacing the starter solenoid (only $7) so how do I test the starter?
Old Oct 12, 2004 | 02:24 PM
mshaud78XLT's Avatar
mshaud78XLT
Just Do IT!
Since you have replaced everything in the system (except ign. switch) replace the starter anyway before winter comes so you won't have to do it lying on the cold ground.
Old Oct 13, 2004 | 01:20 AM
longview1's Avatar
longview1
Banned
If you have your starter out, grab some jumper cables. hook the positive to batt and to the starter (where the wire goes0 then the ground to batt and press on the body of starter, That should tell you if the starter works.
Old Oct 13, 2004 | 08:46 AM
jrfoscue's Avatar
jrfoscue
Thanks for everyones help. I ended up replacing the starter solenoid (which was rusted on one side) and the cable from the solenoid to the starter. Now it starts great. It even starts great after its been running which has always been a problem.
