2WD vs. AWD
Old Oct 11, 2004 | 10:40 PM
scottiea's Avatar
scottiea
2WD vs. AWD
I'm just curious as to some of your thoughts. This is the first truck that I have owned that has an electronic AWD option.
For those of you that have (or had) the AWD option on their Expy 4x4s, which do you use for normal everyday driving 2WD or AWD? What are some of the pros/cons of using one over the other?
Old Oct 11, 2004 | 11:11 PM
buzzard's Avatar
buzzard
I only use A4WD as that's all my '00 Expy has. I presume your truck is a '97 or '98 if you have 2WD selection.
My system has worked flawlessly in the truck's 75K miles.
Old Oct 12, 2004 | 12:53 AM
Monsta's Avatar
Monsta
Sit. Stay.
03s and above have 2WD selection.
Cons of using A4WD is that the hubs are locked. Could result in lower performance.
Old Oct 12, 2004 | 09:40 AM
breslijo's Avatar
breslijo
I guess the question should be 2WD vs 4WD High vs 4WD Low.
The 03, 04, 05 Expedtions only run in those 3 settings.
You can choose the bonus option "A4WD" where the car operates in 2WD and "Automatically" kicks into 4WD High when it determines a certain amount of slipping.
Best rule of thumb, When you need 4WD High, use it. If you just use A4WD, you might not be in 4WD High when you need it.
However, don't use any 4WD for the hell of it!
Old Oct 12, 2004 | 10:42 AM
Bornzo's Avatar
Bornzo
04-When I drive on dry pavement I use 2wd, but when the pavement is wet I switch to A4WD.
Old Oct 15, 2004 | 06:49 AM
wheelzzs's Avatar
wheelzzs
awd vrs. 2wd
With your hubs always being locked in while in awd it's not a good idea to run this way if you have the 2wd option. The hubs are locked in during awd and just more wear and tear on your drive train. We live in heavy duty snow country and this truck is for my wife and i tell her to drive in awd unless its real nasty or when she dosn't feel comfortable put it in 4wd. I personally don't even put it in awd unless the roads are icey or deep snow and most of the time thats if I have passengers. The expedition goes thru most everything anyways, and if i need it, its just a switch away so...........
Old Oct 15, 2004 | 11:02 AM
mcn420's Avatar
mcn420
I would run it in 2wd whenever possible. This isn't an option for me b/c my Y2K X doesn't have the 2wd option from the factory. If its slick out, you go off road, or heaven forbid get stuck, just turn the **** and you're in 4wd. Plus you can do better burnouts in 2wd
Old Oct 15, 2004 | 03:58 PM
blwilli's Avatar
blwilli
Aawd
I leave mine in AAWD, unless i NEED 4X4...I don't have a "2WD" option.
96Aerostar
Aerostar
Jun 8, 2014 11:05 AM
Edlittle
Apr 6, 2014 07:17 PM
2012FordHD
2009 - 2014 F150
17
Nov 14, 2011 02:00 PM
richardliebert
Oct 23, 2011 07:26 PM
007bronco
Aerostar
Nov 21, 2004 03:23 PM
