c-6 adjustment
Old Oct 11, 2004 | 09:31 PM
ford390gashog's Avatar
ford390gashog
c-6 adjustment
is there any benifet from adjusting the bands on the trans and right behind the shift linkage on the trans there is a square plug what is that
Old Oct 11, 2004 | 11:15 PM
smoke n tires's Avatar
smoke n tires
heres how to adjust it. loosen the big lock nut, i think its 15/16, then tighten the square bolt to 110- 120 INCH pounds, next back it off 1.5 turns and retighten the lock nut. thats all you do.
Old Oct 12, 2004 | 09:33 AM
mark a.'s Avatar
mark a.
The plug is a oil p.s.i. test port. My C6 has well over 200k on it & I've never adjusted it.
