door panel removal?
Old Oct 11, 2004 | 10:32 AM
blwilli's Avatar
blwilli
door panel removal?
I would like to replace the stock speakers in my 1999 Expedition (just bought it) and was wondering if anyone knew how to remove the door cards (don't want to damage them you know).
Old Oct 11, 2004 | 12:56 PM
WillieWildcat's Avatar
WillieWildcat
Here you go, these are the instructions from Crutchfield:
Expedition Front Door Speaker Removal
Hope this helps.
Old Oct 11, 2004 | 01:08 PM
PaulC's Avatar
PaulC
Watch speaker depth, particularly for the rear doors, as the speakers abut the window mechanism.
Rear door removal method is similar, except that the rear panels have two screws at the bottom that must be removed.
Old Oct 11, 2004 | 02:30 PM
blwilli's Avatar
blwilli
Thumbs up thank you
that helps me out a LOT!
Old Oct 13, 2004 | 01:17 PM
masinils's Avatar
masinils
Hi.
Any possibility you have the directions for the back panel door removal. I have a small dent that needs to be popped out and need to get the indoor panel off.
Thanks for your help.
Old Oct 13, 2004 | 07:35 PM
Shaggy29's Avatar
Shaggy29
back panel is the same as the front only a bit easier
oops - so much for my 2cents - I failed to notice the year of Expy on this post. I have an 03
Sorry
Old Oct 13, 2004 | 10:36 PM
WillieWildcat
Originally Posted by masinils
Hi.
Here we go, found the rear door sheet.
Expy Rear Door Panel Removal
Good Luck!
Old Oct 14, 2004 | 07:28 AM
masinils's Avatar
masinils
Opps. I forgot to mention I have an 03 Expy. I need to take the cover on the back of the truck (tailgate). Not the rear passenger doors.
Thanks for your help!
Old Oct 14, 2004 | 11:40 AM
Shaggy29's Avatar
Shaggy29
I know the top cap just on the inside snaps off but I have never messed with trim on the liftgate itself
Old Feb 24, 2005 | 03:01 PM
KentuckyMike's Avatar
KentuckyMike
door panel removal here!
use the links below for front and rear removal........
TexasGuy001
Oct 15, 2016 07:57 PM
nuknuk
Aug 22, 2016 04:55 PM
Tom Callan
Jul 31, 2016 12:51 PM
moejr
Jan 10, 2016 02:00 PM
98Econoline150
Jul 3, 2015 04:32 PM
